Those wheels are BBS RD284. They are a 20x9.5 with 20mm offset.
Fun tidbit: BBS calls offset as "ET." ET is short for the German "Einpresstiefe" which translates to "Insertion Depth." (Something
@NLXTACY enjoys a LOT)
I'm also going to let slide the fact that installing 20" wheels on a vehicle designed around 16" wheels isn't good for the suspension, steering system and ride quality. Handling might feel a little better, but it is much more harsh all around.
I digress...
Just from looking at the front of the wheel, I can tell you they won't fit over the hub(which is 106mm OD). I wouldn't take them to a machine shop to open them up because if they machine too far, they will likely intersect with the holes for the lug nuts. This will weaken the wheel (and it will looks like @$$. PLUS those center caps won't fit anymore if you go all the way.
The hubs of the 2000 Tundra and the FJ Cruiser are very similar. They are a semi-floating variant with real stubby protrusions for centering the wheels. Just about any wheel would fit on them. The 20mm offset is almost correct and wouldn't cause much issue. The reason the wheels don't fit on the rear is because the hub is too long.
The OE wheel is 16x8 with 0mm offset and a 106mm center bore(all the way through to fit over the hub).
1.5" is 38.1mm so adding the 1.5" spacer to a wheel with a 20mm offset only pushes the wheel out 18.1mm or ~23/32" widening track width by 36.2mm
2" is 50.8mm so adding the 2" spacer to a wheel with 20mm offset pushes the wheel out 30.8mm or ~1 7/32" widening the track width by 61.6mm
Both of these add to the stress on the hub and trunion bearings(as well as the steering system).
This gives a track width difference of 25.4mm(of course, since that is the proposed difference between the front and rear spacers).
Track width differences between front and rear are usually not more than 10mm. I don't see any real harm other than what was already mentioned. The turning radius will be bigger. The slight stability decrease due to the track width differences are probably washed out by the increased track width.
Also,
@scottryana brings up a good point.
If you are going to run 2" wheel spacers make sure you pull the stock studs and upgrade the studs. While backspacing and spacers don't matter to wheel bearings if the center of the tire is in the right spot, it does matter to studs.
