20" Rims 35" Rubber
Thoughts?
20" TOYOTA ENKEI FACTORY ALLOY WHEEL 6 LUG
What would look better on a white LX450 4" lift and 35" duratrac's.
Also what is the hub dia and lug pattern.
I stayed with 15's on my big ugly, mainly for the price (i'm broke) but if i had the money, i would go with fir first option (polished?) i'm not a big fan of chrime at all, but i like the others. clean lines, simple design and with an aggressive looking tire like the duratracs i think it'd look pretty awesome. Just be sure to post pics!
I like the second set. They will compliment the lines of the
LX. First set is too straight and edgy for me.
7schulz said:
Thoughts?
It's a good looking rim but don't over look the center cap issue....correct me if I'm wrong but the hubs of the 80 are different then the 470 and 570 so you will not get a center cap that will fit the rim and cover the hub.
I'm having the same issue with the Rock Monster Hutchinson rims .... Treeroot is running them on his rig .... Not 20's but 17's... with the correct bolt pattern and offset but the center caps are not deep enough to fit...I think you have the same issue with this rim
Lou
Sent from my iPad using IH8MUD
Lou, still looking into the hub dia of these rims, we need 110 mm and the chrome ones are 106.2. so they are out, I have also found a set just like the chrome ones with 6 lugs but with 7 spoke design, they are off a 2008 Texas Edition Tundra I believe.
If the hub dia is large enough on these I think I will order a set up. Looks like they come on the Tacoma X-SP
What do ya'll think of this rim on this truck. Only problem is the rim has a hub dia of 106mm. Does anyone have this rim on their tacoma or tundra and can look at the back side to see if the hub could be machined out to fit the axle hub through?
Thought being that this rim and our rims have the same lug pattern and material so there should be enough material to machine out 4mm and still be structurally sound.??
Keep in mind that your offset will probably be way off requiring the use of spacers.
Here is the back of the rim. Think that lip could be machined out to fit the 110mm hub through. This is the Enkei rim and is the only 20 inch 6 lug toyota rim I could really find that would work.
