Trying to remove the carriage bolts from the front bumper to the frame (1 Viewer)
DKM
UT
78 fj40. Is there a trick to removing these? I am loosening the nut on the back (by turning it to the right), but the nut isn't making its way down the thread, if that makes sense. It just spins, but the carriage bolt itself isn't spinning. From what I can see, the carriage bolt has a square under the dome which sits in a square hole in the bumper. The carriage head isn't spinning, so the square hole isn't rounded out. This is driving me crazy. Any help or tips are appreciated. Sorry to clutter the board with what is probably a stupid question. Appreciate you guys.
Kind of a small space for a sawzall. While not as quick a Dremel would do the job just requires patience. Another oprltion is to use a small punch to mark the center of the carriage bolt head. Drive a small hole deep enough to be into nut. Then keep stepping up the size of the bit. Once your close to the thread size a punch a little smaller will probably pop the head off and then rest should drive thru. Bolt and nut are trash. When I'done I don't want to damage anything but those.
I was going to take a portaband to it this weekend and see if I can get it between the head and the bumper, but a dremel might be better. Thanks for the suggestion. I'll reply after I get it done so future searches can see this thread and how it turned out/lessons learned.
I have had great success using an oscillating tool to cut bolts. Just need to buy a good blade. I used it to cut the OEM rear body mounts.
Does sound like the threads are stripped, could be the nut or bolt, perhaps some of each. Big punch and a hammer to drive out the bolt. Torch it off or drill it out. Bolts and nuts are cheap. A cut off wheel in a Dremel to put a cut line in the nut, then use a cold chisel to split the nut.
Or if there is enough room.. A nut splitter is a good tool as well.
I think a drill would cause less damaging to the bumper.
Probably not as bad as a sawzall. By the location not sure how well I could free hand in this awkward tight location. Especially if it one them in between the frame rails.
One tool I've never collected. This is one location might be a great choice.
I Agree, hate rushing a job only too end up creating more work. I have a slow RPM 1/2" electric drill. Using high quality bits it cuts thru bolts quickly.
Well, been working on some other stuff and finally came back to these. Can I just say I hate carriage bolts? At this rate this thing will be done in 20 years. The oscillating tool worked great on the two bolts with the stripped threads. I've been able to get some other nuts off using PB blaster, heat and a breaker bar. Now, stupid question, but with the nut off I should just be able to push the bolt straight up and out, right? It's not budging. Thought I'd check here before I start banging my hammer on the bottom of the bolt to pop it up. Here's the pic of the bolt with the nut off. Thanks guys.
Looks like that washer is rusted in place locking the bolt. Use an old wood chisel under the washer to break it loose. Put the nut on a few threads and then BFH time.
Success. Wood chisel and some taps between the washer, then used the chisel between the dome of the carriage bolt and the top of the bumper and it brought it up a bit, then I grabbed it with some grips and yanked her out. BFH will be saved and pent up for another frustration. Got the last two out. Appreciate the advice, Charlie.
