truck will not idle and bucks under half throttle under 2000 rpm. (2 Viewers)
Orange County, NY
So after 4 days of searching and trying to diagnose the problem I figured it's time for me to start my own thread in order to get some adequate help. have checked the fuses and wiring to the ICS, I have also disconnected the hose from the EGR and still will not idle. I didn't however check the voltage at the ICS though. The problem started about a week ago after replacing and refreshing all my vacuum lines. As a precaution I said to myself to better change all of them so that I would not run into trouble down the line. She ran just fine after that for a couple days. Then, probably coincidentally, or perhaps I damaged something, she started to not hold the idle anymore. It sounds very sputter-y, cutting out a lot. Kind of like an old airplane engine. She also bucks a lot under light throttle. Will run just as usual under heavy throttle. Truck never idled below 1000 rpm after driving off. Only after fresh start and warming up, she'd idle at around 6 to 7 hundred. Truck ran and still runs great otherwise. I have discovered that the purple BVSV had a broken nipple but since has been fixed. She still ran fine even with the broken nipple. After searching I read that that BVSV can be bypassed anyway. I opted for a new one courtesy of a fellow forum member. The truck had a previous very partial desmog perhaps, since some vacuum lines are missing. Only 2 on the pass side of the engine. There is a white 4 or 5 way valve with 2 nipples blocked off and that's about it. Also at the carb there is a "Y' connector bringing together 2 lines that otherwise would not be together as per the diagram I have downloaded here on the forum. I will take a couple pictures and post them for reference. Any way, I don't think that's a problem as I've had the truck for more than a year and it's been perfectly fine till now. Help please. Much appreciated.
Perhaps we could have a clue as to what year and model engine?
Did you run the vacuum lines in a desmogged format, or did you incorporate all of the smog equipment and return it to the factory hose routing? Pics would sure help.
Actually I di not cange a thing and ive done them one by one so as to jot mess anything up.
Have you checked your idle speed adjustment and idle mixture. Could be off and that is why it will suddenly not idle.
I did not but its been fine till now. I did not want to mess with the carb. I did find in my searches that fj40jim recommends 4 turns from bottom on the idle adjustment. Might have to try that as well.
Hi, How old is the fuel pump and filter? MIke
i have dismissed the two because it works fine under full throttle although a clogged filter might cause faulty idle i guess. I might have to disconnect some hoses to see. Also, I have a new filter that i will install. I don't have someone who can crank the engine while i check to see.
Ok fellas, I know its Christmas day and a lot of you aren't on the forum but I just checked the ICS and it seems to function as it should. Checked gas filter and it's clean. Only pump remains to be checked. I will order a new one just to refresh it anyway. All vacuum lines seem to be good and everything seems to function good. What gives? she still will not hold an idle regardless of whether its choked or not. Help please.
pics of engine bay and the partial desmog.
Have a look at the vacuum line to your distributor. It sounds a little like your not getting the timing retard you need.
Bill
Bill
i will check and report. bear in mind it ran fine since i got it more than a year ago. i do seem to hear a whistle though from somewhere under the hood that i don't remember hearing before. it must be a vacuum leak somewhere. i must get someone to try and hold the idle while i check.
Keep a fire extinguisher nearby and start spraying brake fluid to see where the vac leak is.
I cannot keep it running. Some one needs to help me out as i look under the hood. I guess i have to wait a couple days till i get my bro to come over and help out
OK, so no leak at the distributor. What else should I check?
When you checked it did you pop the cap and suck on suck on the vacuum hose to verify the the distributor turns and holds as long as the vacuum is held? TBS, it's probably not that since it should still idle, but just not have any power.
The dizzy holds good vacuum. What next? I was supposed to take my daughter boarding tomorrow. I dont want o put ourselves in any danger. I lost the idle whole coming to a stop and the brakes went. Barely stopped.
check for vacuum leak at the brake booster
