Gretsch
Hi all. I discovered a very worn TRE on my '84. I was planning on replacing these when I did my knuckle rebuild but this thing was shut down bad IMO so I decided to go ahead and get the TRE's handled. Ordered a set from Cruiser Outfitters and installed them today. Went smooth. Steering wheel was straight when I started but after finishing this job I got in and the steering wheel is way off. Driving straight it looks like the truck is turning right pretty good. I was sure to count the threads on all the TREs before removing them and even them marked them just to make sure I had it right. If I look under the truck the pitman arm is pointed straight forward and the wheels look mostly straight but the steering wheel is totally off to the right. I also hear various periodic pops and clunks when turning. Does not happen all the time but its like something is loose. When replacing the TREs, I tightened the castle nuts until I got them good and tight by hand. Then I tightened them a bot more to align the cotter pin hole. Now the studs on the TRE's seem to 'seat' into the hole of say the knuckle steering arm. Is it possible I did not seat them properly causing them to move around creating popping noises? See photo below of one of the TREs installed:
This looks to me to be the way the old ones were installed so not sure they would be 'unseated'.
As for the steering wheel be off, it was off a bit before but the play in the original TRE may have compensated for the it a bit. Truck has always wandered a bit and has recently developed death wobble at around 35-45 MPH. After the TRE replacement no more wobble so that's good. But the steering wheel being so off makes me think I have messed up somewhere. If the pitman arm is pointed straight forward along with the wheels, should I just take the steering wheel off and center it? The PO fixed the horn somehow and maybe took steering wheel off? Not sure if that would be needed for the horn fix or not. Or should the pitman arm be pointed some other direction and I should adjust the TRE that connects to it to correct this. See phots below of what was done. If anyone can spot something wrong here I would appreciate you pointing it out.
Thanks in advance for all the help.
