Ok think I sorted the starter issue. Now onwards!
I am planning to do a transmission flush and found instruction on here:
"You dont. You can brake the line closer to the radiator.
Thats how I did mine. I got a two liter coke bottle, pored in two quarts of fluid, marked a line on the bottle. Then I drained the pan, refilled it, started the engine.
With a hose in the bottle, I'd watch the old fluid fill the bottle to the line, stop the engine, dump the dirty, add two quarts to the trans and start all over, when I got to 16 quarts, I hooked up the cooler line, than started the engine and topped off the trans.
I used 18 quarts as to make sure I got a good flush. I believe the trans holds 16qt."
I'd much prefer to not drop the front axle for access, but mine also has the transmission cooler. My question being - Does the cooler alter where to disconnect from? Can someone offer insight on best place to disconnect from closer to the radiator/cooler to not have to drop the front axle?
Working on a 1988 FJ62 with automatic trans
Thanks gents and thank you
