I just rebuilt the transfercase in my Troopy and within 2 weeks my transfercase in my 62 went out. By that I mean it made a loud metalic bang sound; the truck didn't slow down or stop, but when i got to the house, fluid was coming out of the case. On inspection i found a crack in the case near the drain plug. I knew right away something came apart inside and impacted a gear and the side wall of the case. After taking the split case apart I found the idler gear with one tooth completey broke off and some other teeth damaged. The low range gear has a few gouged teeth but nothing broke off, so I'm cleaning it up and reusing it. I found a used idler gear for $250 and the transfercase rebuild kit for $235. To replace the transfercase is about $3600 from SOR and I haven't found it used anywhere. I'm hoping I can get the crack in the case welded up. If not, does anyone know where to get the outer case by itself?
