brooklyn said:Put carpets, dynamat, and heavier oil - made a big difference. Less road noise and fumes in the cab. Not too expensive and easy to do.
That will solve most of your problems right there.I haven't really thought about heavier oil. it does seem louder now than it was before the tear down. I had to change the oil to install the twin stick kit. what weight do you recommend to make it quieter?
I might do dynamat under the hump. and I need to fit boots to the shifters.
Wonder if you could just apply the dynomat to the t-case. lol
that might cause some heating issues.No, really. Maybe it would quiet it down some if you sprayed it with bedliner.
texfj40 said:Just a thought, mentioned many times. Gear oil sometimes leaks from the t-case to trans. Overloads trans and empties t-case. Check it out. There are cheap hoses made to return oil from trans back to t-case. Good idea, that hose!
