1973Guppie
Supporting Vendor
So, I performed this mod this past weekend and thought I would post a quick writeup to hopefully benefit others whom may want to do this mod on their own. There are vendors here on the board that can swap out your speedo for very little $$ but I decided to try my hand at doing this myself as I will have to do it again on my FJ55 transfer case here soon. Plus I seem to always take the hard way,
For people whom don't know, this is the mod where you file off the lip on a 3spd transfer case where the seal sits on the speedo housing. It is a common ailment that the drum emergency brake spline piece that sits on the seal gets scored over time and it a point for leaking. Obvious signs of this for me were excessive leaking when parked up hill and dripping from my speedo cable. The remedy is to grind off the lip, fit 2 seals in the speedo and speedi sleeve the old e brake drum.
not much more typing than this, let me know if I can help anyone, questions?, or if anyone has anything to add......
almost forgot, big thanks to Pinhead for giving me tips on this and sending me the proper bit to use...
Step 1 - remove everything, dshaft, drum, ebrake hardware, then the speedo housing....
