Does a 96 80 series have a factory trailer wiring harness setup under the body near the rear of the vehicle? I am getting ready to wire up a trailer wiring harness, but I would like to use a factory wiring harness if possible.
Start with a Hoppy plug and play. Runs less than $50 and plugs right into your wiring harness at the rear tail lights inside the truck behind the panels. NO wire cutting and splicing! From there a decent trailer place can set you up with the rest to get you to a 7-pin if you need it.
This is what I used for my '95. It looks like it has been replace by this unit:Lexus / Toyota
You may want to read this thread too. It explains where to tap into the brakes for you brake controller.
Break controller wiring harness?
