- Thread starter
- #41
I would guess head gasket and or head damage. White puffs were coolant traveling through a cylinder and out the tailpipe. After you stopped the truck, the coolant level in the head gravity fed down towards the earth and seeped into the cylinder with a piston in low position and keeps the truck from turning over (hydrolock). None of that is a big deal. Pull the spark plugs and look at them. Then turn the motor over with no plugs in and see what comes out the spark plug holes (disconnect the top center wire from dizzy to stop any spark from happening).
Also, drain the oil into a pan and see if you have coolant in the oil.
All of that would be work required prior to taking the head off to complete the repair. If the head is damaged, you won't know until it is off. If the block is damaged, you won't know until the head is off. All of that can be done with the engine in the truck. I wouldn't pay a LandCruiser shop more than 3 or 4 hours to have the head entirely removed and troubleshooting complete.
Good luck!
Not sure I'm actually turning anything over with the spark plugs unattached. I labeled each wire from the distributor, then unplugged them and ratcheted out each spark plug. With everything detached including the center wire from the distributor, I went to crank the car. A little help here? Pardon my ignorance.
