In my case the OEM rack bushings were tooooo soft =[ Can't justify removing them to install aftermarket.
Even with this much play I don't have any issues with stability control kicking on so other parts are most likely the culprit when people have this problem.
You''ll see about the same side to side movement, with new OEM rack.
I look at:
Rack side to side movement.
Bushing rubber condition, or what little can be seen. In 03- "has bushing cup turned".
Road test, for HWY wandering.
Road test for steering recovery from turns.
Inspect other front end components, that may also contribute to wandering on HWY.
Weigh in rack leaks, if any.
Weight in inner and out TRE condition.
Advantage of new OEM:
OEM mounting bushing.
OEM inner TRE's included.
