FrazzledHunter
Nice camper!Say hello to ih8mud's newest towing family!!!
Today was introduction and walk-through day at General RV in West Chester PA!
This is the first time we've seen our new trailer and we're very happy with it.
The custom electrical job to allow for charging the lithium batteries from the tow vehicle was primo IMHO.
Tomorrow morning is teach us how to hitch up and we're headed home hopefully by 11AM.
Thanks to @linuxgod, @eatSleepWoof and all the others who have given words of encouragement and most importantly knowledge.
We are truly grateful for everyone's help.
FWIW I find I need to turn the controller up a bit on the highway and down a bit around town. YMMV of course. If you’re locking the trailer brakes up though, turn it down slightly. If they lock up around town you’ll know it because your wife will shrink down in her seat hoping nobody heard you stopThe wife and I just took 2 laps around the lot with the tech. We jerk stopped to calibrate the REDARC Tow Pro. It stops smooth as butter. It pulls our trailer like nuthin'. The mighty 200 rocks!!!![]()
We started at 6 and backed it down to 3. At 6 the trailer was stopping the LC!!! Thanks for the tip. We'll experiment around with it.FWIW I find I need to turn the controller up a bit on the highway and down a bit around town. YMMV of course. If you’re locking the trailer brakes up though, turn it down slightly. If they lock up around town you’ll know it because your wife will shrink down in her seat hoping nobody heard you stop![]()
Yes I am sure. You should not 100% charge them if you do not have to. And you should not completely drain them if you dont have to.Are you sure it’s problematic to keep them at 100%? I know lithium ion in cell phones and EVs don’t like it but my LiFePO batteries in my trailer are different chemistry and 100% charge is just fine.
At a technical/battery-chemistry level, this is correct.Yes I am sure. You should not 100% charge them if you do not have to. And you should not completely drain them if you dont have to.
But there is the question of practicality/value, too. My 100ah batteries cost me $315CAD each, shipped to my door. They are advertised as being good for "up to" 7000 battery cycles.
In the most optimistic projection, we'd camp 50 days per year. (Fat chance, but a man can dream.) My 2x100ah should be able to run my trailer for about 3.5 days. That means 14 cycles per year from camping, but let's round it up to 20 for the year. Even if the battery only gives me 700 cycles (10x less than advertised), that is far, far above what I actually need, and I'll almost certainly have a different trailer by the time the batteries need replacement.
Heck, even if they need to be replaced in as few as 3 years... it's $630CAD. I'll spend 10x more on gas by then.
Which leads me to ask... is keeping the batteries in the optimal charge range worth the worry/headache? For me, no. I'll keep them charged at 100% in transit, to give myself the max camping length/comfort, and replace them when/as needed.
Side question not related directly to towing. I currently have a 3000W inverter. I went that big so I can run A/C or the microwave off the inverter if needed, which I have done a few times. But I would say 99% of the time we are only using a couple hundred watts(lets say anywhere from 100-300) a most to maybe charge laptors or other smaller stuff.
Is it worth getting a second smaller inverter, maybe a 700W, so that it runs more efficiently when drawing less power?
In general, I don't like duplicating components for the same use cases unless there were a significant driving reason. I don't know what the standby draw of the 3k inverter is relative to a 700W? Is it enough to warrant another inverter? Maybe could make-up the difference charging your LiFePO4s to a higher state of charge, or getting more solar as IMO 200W solar is undersized for 510Ah of battery?
That said, I do have 2x inverters in my trailer. A 2k one built in (that can run the A/C). Another that's a part of a GoalZero 1000 portable solar generator. Both are wired such that they are capable of powering the whole trailers 120V via automatic transfer switches. The GZ is nice as the integrated 1500W inverter only draws 7W. 2k built-in inverter draws <20W. Both can be on standby practically forever.
I mention the portable solar generator as it expands the use cases it can support. I can easily take-out the battery to run a blender or coffee maker etc away from the trailer. Also allows me to have two banks to draw down depending on situation. And I can charge the GZ away from the trailer. "Installing" it is as easy as plugging in a 12V cig lighter for charge maintenance, and 120V pigtail to power the trailer.
That's some impressive solar numbers. Must be one of the perks of living in Utah.As for the 200W of solar. It works fine for me because we usually have clear skies and I dont have them roof mounted. I put them on our gravity chairs and keep them perpendicular to the sun all day. I often see 11-12A to the batteries and can usually put about 60 AH into the batteries on a good day. Even 2 weeks ago on my trip I was seeing 11A in February.
It was less about the standby power than the efficiency of the inverter while operating. An inverter operating at 5% load is relatively inefficient compared to a 30% load. If my wife and I do a working camp trip where we are on laptops all day then we are drawing whatever the laptops are drawing for 8 hours. Lets just say that's 150W between the two(mine is a Lenovo P1 with dedicated GPU and 170W power adapter), my 3000W inverter is probably at 80% efficiency while a 700 would be at 95%+.
So now Im talking 1500 Whr vs 1250 Whr used per day. Its not a huge difference but a difference none the less.
I dont leave my inverters on while not in use so standby draw does not worry me too much.
Gotcha, makes sense. There are some other opportunities if efficiency is the goal. Using 12V natively (sorta) using USB-C would be more efficient than an inverter. 170W would be sporty but unless you're hardcore computing or gaming all day, USB-C should easily keep up.
I'd encourage you to look at installed solar as it really rounds out the power solution. For probably the same reason you installed a large battery bank, installed solar makes for an effortless power system that could supplant the need for any DC-DC from the car, or plugging in at home or at sites. I don't even have a working converter in the trailer because 400W of solar is that good and I almost never plug-in. As you know, batteries only store, but solar is a real source of perpetual power.
Problem is my laptop wont even charge off a PD USB charger if its less than like 100W i think. I tried my wifes Lenovo USB C 65W charger and my laptop just sits there and does nothing.
Well we made it home JUST FINE!!!
I hate to say it and maybe jinx the good luck streak but it was actually a piece of cake.
We did stay off Rt 95 but we did run around the Baltimore Beltway (Rt 695) and then Rt 70W.
We ran in S6 and ECT most of the time which is what I gathered from this thread is the best.
By far the biggest PITA was getting stuck behind a Prius for about 15 miles doing 45MPH in a 55MPH zone, no doubt trying to save gas.
- The LC towed the trailer like it wasn't there.
- ECT makes a difference - much less shifting around.
- We used a lot of gas: 10-12 MPG LOL.
- The suspension on the trailer (Dexter Torflex) was very smooth even over some washboard areas.
- I monitored some things with my OBD Link
- ATF temps were nominal but this was highway driving with an empty trailer.
- Only surprise was how long the LC stayed in 6th even climbing some hills.
I'm only guessing. We ran around town a bit before we hitched up. I'll have much better numbers after a few full to near-empty fills when we're towing 100% of the time between fills.10-12 is very good IMHO. My trip 2 weeks ago I averaged 7.9 on the way there, 7.5 to the second state park we went to, and 8.5 on the way home.
I towed ~20,000 miles with my F150 Ecoboost and saw anything from 6.7 to 10.8 average depending on conditions. 6.7 was driving from the Black Hills back to UT as an early season snowstorm was blowing across WY. 10.8 was also in WY heading east with a stout tailwind. My overall average was probably around 9.
Wow, 10+ mpg. I’m jealous. I usually get about 7 to 7.5Well we made it home JUST FINE!!!
