Torsion Bar Bolts Size?
TLH, FL
Hello, anyone know the size of the bolts located at the front of the torsion bars? I'm going to need to repair the threads on one of those. Thanks
The bolts holding the bracket to the lower control arm?
M16 - 1.5 for anyone else that does the same.
Just make sure you damage the threads on the bolt that you can't remove. It makes for a lot more fun :sorry:
I assume you had to remove the LCA?
Luckily, I did not. 22mm open end box wrench to hold the bolt in place from the back, you can just squeeze it in there. Then I used curved locking pliers to slowly advance the die along at a snail's pace while lying on my back, under the vehicle, in AZ heat, in my garage, it was fun.
Use OEM-
