- Thread starter
- #21
Thank you!
So for paint, I have tried a bunch of things over the years… like you said, people either love or hate the POR15. I personally don’t like it. I followed all the instructions carefully and did all the steps, but it still peeled off in sheets.
I like Chassis Saver by Magnum Paints better, but only in certain applications. I found that if you sandblast something and then use the Chassis Saver, it sticks like glue. If you have surface rust, it sticks okay but it doesn’t get rid of the rust. It encapsulates it so it won’t spread, but if you sand it off the rust is still there. Clean metal has to be really roughed up for the Chassis Saver to stick…that’s why sand blasting is so good.
Lately I’ve found that cleaning everything to bright shiny metal is the way to go (if you can). Then you don’t have to worry about the rust popping back up. I have been really liking Eastwood’s Platinum Rust Encapsulator. It can go over roughed up clean metal, painted areas and rust. I then top coat that with spray paint (choose your favorite).
I have done this on multiple sections of my frame and when I had to sand it off it was really stuck on there. It also revealed that the metal underneath was still clean with zero rust.
No paint system is perfect. They all have a bit of a give and take. It’s important to be thorough so you don’t have to do it again. Also, the original frame paint is probably the best protection so if you have areas that are still intact, rough them up and paint over them. Don’t sand it off.
I have also been using Eastwoods Internal Frame Coating. This is expensive, but works well for most things. It is really runny, so it will creep into crevices and it dries fast. I then top coat with spray paint. For example, I coated the 80 axle I am using with internal frame coating and then top coated with VHT spray paint.
Lastly, I like to use Cosmoline RP-342 in some areas that get excessive abuse. This is a wax that repels water. It sticks like glue but will come off with a solvent if you need it to.
It gives just a little extra protection. The only downside I have found is that it makes your frame look kind of dirty (even after you wash it)…but in my opinion it’s worth the protection it provides.
