On-Board Air .... ARB Twin Comp / Slee Bracket.
Alright kids, its way late out here in the east coast, time to catch some zzz's and will continue tomorrow when I get more time, night.
this is turning into a proper build thread now... kudos!
ScanGauge II...
Is it normal for the trans to hit 212f to 220f on these things? I remember as soon as my 4Runner started climbing to those numbers (mostly due to weight and slightly larger tires) I installed an aux trans cooler, temps lived in the 170's after that.
I don't think your 285/65R18's are significantly large enough to require re-gearing, but taller tires will lower RPMs and cause the torque converter to work harder, which can raise the fluid temps a bit.
Pan temp on mine seems to run 196-200F when towing in 4th gear. Outdoor temp (60-90F) seems to have little effect. Highest I've seen was ~203F when pulling through some of the mountains in Wyoming over the summer. Torque converter temp runs hotter, particuarly when the TC isn't locked under load or when it's not in 4th gear. I've noticed when cruising but not towing that the pan temps run around 200F in 6th gear, maybe slightly higher a couple degrees higher depending on altitude and outdoor temp. They'll climb up to 210F+ if you're heavy on the gas pedal since the TC will generate heat the harder it works, especially if unlocked.
FWIW there's a "warmer" on the AT line which is designed to get the fluid temp up to operating temp quicker to improve mileage. I don't think it's possible to get the temp below ~195F unless you remove that. That said I'm pretty sure Toyota engineers know what they're doing and Toyota ATF WS is designed to run at the warmer 195-200F temps all day long.
Looking good. So how tall is the LC now? It's still going in the garage with that Gobi?
This castrol super clean stuff is AWESOME for engine bay cleaning (65% water 35% super clean mix on a spray bottle.... rinse with water before and after)
Leave only for a few seconds (under a minute).
Can you post the exact name of the engine bay cleaner you used? I can't find Castrol Super Clean...
Looks great!!
Damn, you move fast. She looks fantastic, well done. I love that rear hatch light too. I Would love to do something like that but I am a mechanical tard.
