I just put a rebuilt Aisin carb on my '83 FJ60, and I cannot get her to idle without the choke. The solenoid clicks when the key is turned, the correct wire is grounded and the hot wire reads 11 Volts. The vacuum gauge at the intake manifold reads ~17 with the choke out enough to keep her alive (a little above 1000), and she revs and sounds fine. The odometer broke at 260,000 miles, the engine compartment is a mess of dirty tangled vacuum lines and old appliances. The hose from the top of the air cleaner (closest to carb) is disconnected from the air pump, and it has no vanes to attach to.
I also have a new aftermarket Japanese carb from CityRacerLLC designed for a desmog, and I have to decide whether to go through the FS emissions manual and try and figure out why it won't idle , or whether to take everything out and desmog.
Is it worth it to desmog? I've read through the threads on here, and I understand the basics and know the engine pretty well, but I am in school, and I can't find an estimate of how much time/ work it will really take.
