Guy,
Marc needs to give you John's HAM study book. He doesn't go wheeling so he won't ever need a HAM radio anyway.
decision made... FT-8800R from Hamcity
So, help me select the antenna and anything else needed for the install. I'd like to hardmount the antenna instead of mag mount.
Currently review threads of antenna installations on 40's...
that will be a nice radio.
The nice thing about a 5/8 wave antenna (as told to me by Cruiserdrew and Rusty_tlc) is it is not ground plane sensitive. Most of us are running the Larsen LM150 whip antennas out here...I think Andy was the first. Tough, flexible and they just work. This antenna is a single band 2m antenna...not a dually.
More here: design your own 5/8 wave vertical antenna
For an antenna I would start out with either a Comet SBB-1 or SBB-2. Then if you want to go bigger later, you can. Most folks here use a NMO mount of some kind. I have no idea what to suggest for a mount on a FJ40.
Onur, Mike and I are victim to low branches and this antenna.
Good, glad to see that you are logical.
Where's my morning coffee.....![]()
As been also said, only go with NMO mounts.
i STRONGLY suggest NMO style mount (strong, easy to swap, common, etc).
Just a correction:
1/2 wave will give better SWR than 5/8 if you lack a good ground plane.
If you have a good reflector(ground plane) then the 5/8 wave will give better electrical performance.
... My understanding is, from what he told me, the 1/2 wave with a good ground plane will outperform the 5/8 without a good ground plane but not visa versa...
And the shape of the hood does not lend itself to traditional lip mounts I'm pretty sure, so you're left with either the bumpers or the roll bar/cage. And the cage is out, if you ever run more than a bikini top.
