Builds TN LX570 Build Thread
Paint the handles on the truck?
No, I removed them. You probably could if you taped up everything really well, but they aren’t too bad to take of.
Slee Rear On
Install Highlights
Finished getting the lockers plumbed this weekend. Was able to fish the line almost entirely through the drivers side frame rail to the rear end. I’m sure the plastic line that comes with the lockers would hold up fine, but I’m really happy with these braided lines and fittings.
Nice!
That ARB hose pissed me off so bad, until slee commented about being able to re-clock the fitting with a vice and big wrench.
Here’s the video if you ever want to get that kink out:
Nice!
Here’s the video if you ever want to get that link out:
Thanks. I felt like the line was just a smidge short, but they may take care of it.
Installed the Garmin Mini 2 Dash cam last weekend. So far so good. Install was super easy. I sprung for their hardwire cable kit, which gives you a couple of nice features.
You can set a low battery shutoff voltage. Also, it connects to 12v constant as well as ignition on. Which helps to dictate the recording mode for parked vs driving.
The camera itself is super small and not visible from the driver’s seat behind the mirror. It was surprisingly easy to snake the wire up and tuck it in above the head liner. I did it on the passenger side and picked up the 12v and Ignition on from the little fuse block under the glove box.
Voltage selection jumper
Example Footage
This may have solved all my reservations of getting a dashcam. Except maybe that it would capture my own stupidity...
Thanks for posting and I might just pull the trigger.
Added 4 of the Stedi 5700k rock lights in their nifty little rhino rack mounts (which could really be used in any rack with a hole).
Nice and bright.
Damn these are nice! I wish I'd seen these before I made my "alley" lights off my Rhino Rack.
Just a couple of small things updated.
Pro clip USA MagSafe mount. Apple oem MagSafe charger = 15w of wireless charging and the phone held firmly in place.
Getting ready for next weekend’s winch install. Added a 2nd Voswitch (filled up the first one). Relocated the side curtain airbag switch, which had been replaced by the locker dial.
I love the look, but maybe I’m partial!
Just a heads up: I have 5/8” gap between the bumper and skin and every bit of it gets eaten up during a flex.
