Tko sliders install notes
central florida
Tko makes sliders for an lx570.
If you live near Georgia they’ll install them for you for a reasonable price
This is a pretty easy job
Necessary tools:
Wobble head ratcheting 12mm wrench
Box knife
Sandpaper/sander
Panel popper
Recommended additional tools:
Thread cleaner 1.25-8
Electric ratchet
Whole set of 1/4” extensions
Good 1/4” swivel or swiveling 12mm socket
Floor Jack
Masking tape
(Going on memory)
There’s a better thread for cutting the side steps so I’m not going to go in depth on that
Post in thread 'LX570 Running Board Removal'
LX570 Running Board Removal - https://forum.ih8mud.com/threads/lx570-running-board-removal.966384/post-14737557
1. Use a panel popper to remove the tread plate from the side steps (see other thread)
2. Continue using the panel popper to disassemble the stuff under the tread plate (see other thread)…remove the wiring and bulb from the entry courtesy light in the side step.
3. Use masking tape to make a lines you plan to cut on your running boards (see other thread)
4. Conservatively score the line using the utility knife…continue scoring in the same line until you can penetrate the plastic and fully cut the sill. Sand your cuts.
5. Remove the steel brackets that attach the running boards to the vehicle
6. Remove the ahc globe cages/stock sliders (keep the fasteners)…this is where a wobble head ratcheting wrench is handy…as well as an electric ratchet with lots of 1/4” extensions and a a swivel…speeds things up quite a bit. Once the fasteners are out, lift upwards and pull outwards on the cages (they have a hanger that holds them in place on the frame-smart design)
7. Use a thread cleaner to clean the threads on the ahc globe cage fasteners (you’re going to reuse them and “threading” the bolts with minimal clearance for your hands is markedly easier if you have very clean threads on the bolts.
8. Rest the slider on a floor Jack and strap it down just forward of the 3rd support (it’ll balance)
9. Raise the slider into place using the jack
10. Affix the forward most and rearward most fasteners (front one is easy, rearward lowest most one is best threaded/loosely affixed using extensions between the slider and body of vehicle)…don’t completely tighten these or any other fastener until you’re done. you want enough wiggle room to lift, lower, push, or pull the slider to make sure you have not occluded the access to the various bolt holes you’ll be threading fasteners to
11. Remove the floor Jack so you’ll have more access to the bolts
12. Affix the remaining 6 (thread cleaned) bolts. I strongly recommend you get each of these started using your fingers, not a ratchet or electric ratchet-the angle is tough and the fasteners are chamfered. It’s a recipe for cross threading or damaging threads in the frame. The easiest way to have the “space” to thread these is to put your entire body under the vehicle perpendicular to the sill (or use a lift if you’ve got one). The bolt holes will be right above your face and your hands will be in a natural position. I ended up, once I figured out the right “angle” to be physically at, just using a ratcheting wrench at this point…that way I didn’t need to keep getting up or adding various lengths of ratchet extensions.
12. Torque down all your fasteners
13. Install ahc skid plates to the sliders.
The seller says these ship at 85 lbs. Considering how much plastic and metal I removed from the stock running boards, I doubt I’ve added a significant amount of weight to the vehicle.
Also, even with only a few fasteners affixed, I was still able to Jack the whole vehicle up using these sliders.
Those look bomber. Rig looks great too!
Glad to see another option out there.
Cool. Good to have more LX slider options.
So they use the same holes as the metal rods / oem ahc protection do?
Yep. 8 of the 10 holes I think.
Just picked up a 200, considering these since metaltech costs over twice as much . Anyone know how fast the lead time is for the TKO?
Website says 3-4 weeks. Will these work with a 2011 LC200?
I doubt it, looks like it mounts around the AHC cage bolt points
They use the ahc cage mount points and hardware.
Unless your 200 series came equipped with ahc (I don’t think any land cruisers in United States had it) I doubt your frame has the mount points.
Can you take more pics fructose? Curious with the door open does it stick out enough to step on it and get in on the front part.
So sliders weigh like 85lbs together, the cage and running board we will be removing gotta be at least 40 lbs so this shouldn’t add on too much.
Due to the excess depth associated w being able to slightly tuck your feet under the body…you gain an easier entry with these vs oem.
Also, with the kick out in the rear it really helps w backseat access…as well as the obvious benefit of kicking your vehicle away from a rock/tree if you happen to end up to close
Oh wow that's a good visual, thanks for taking the effort. Love this forum, people be up and early with a camera ready to help out others lol.
I think i'm sold on these, will place an order today. I just ordered Victory 4x4 rack and they said 2-3 weeks lead time too, i'm so impatient when i order stuff i want it now.
Edit: just ordered, now the painful wait time
Anyone with the high-and-tight style have some good photos? Is it still possible to use them as a ledge or are they completely tucked against the bodywork?
I just got email confirmation that my sliders have shipped, should be here by Tuesday!
For the record, you cut the plastic off the running boards while it’s attached to the truck still?
Yes. I, carefully, used a box cutter/utility knife to score the line I wanted (after marking it with painters tape)…then went back over that scored line deepening it until I was able and cut through and straight across.
If you have an airsaw that’s likely the “best” way to do it…I decided to go slow, careful, and simple. Only took like 20 minutes and I was able to be conservative…and then remove more as needed.
Man why did I get so worked up doing the running board removal and trimming the rocker. It’s really simple once you get to it and see how everything is held up. I did both sides under 30 minutes and that includes checking this thread several times to compare the angle of the cut. I used a 5” cutting disc on an angle grinder.
TKO sliders will be here tomorrow, I’m thinking of painting them gunmetal so there’s some contrast to the sliders and the black car paint. Or a very dark gray color
