Order placed today. He quoted me 95 shipping to Louisiana.
Great guy to deal with.
non-lemmingsYeah, and who uses it!?
I'm curious, do the instructions specify feet forward mounting only? (it doesn't look like there are additional forward supports for feet down mounting)
For reference. My winch shipped on 10/6/2011. From Ontario to Seattle WA, and it took 6 calendar days (4 business) to reach me via FEDEX Ground. Total shipping costs, $108 USD. ZERO hassle, delays, or fees for the winch passing through customs.
Can you post some pics of the unboxing when you get to it?
The winch can be mounted anyway necessary. The ARB 03+ bumper for the 100-Series requires the winch to be mounted feet forward. It's the only option if you want a winch in that bumper.
There is no issue with the Titan, you can mount the winch feet forward right out of the box and it will work perfectly. However the clutch handle will be facing rearward, and not the most ideal location to reach from the top of the bumper. So to resolve that issue you can remove the gearbox on the Titan and "clock" or rotate it, so the clutch handle is again facing straight up as if the winch was mounted feet down.
This "clocking" issue is universal with any winch, including Warn and others. In fact the instructions that come with the ARB bumper instruct you to clock the winch gear box on your Warn to resolve the clutch handle angle.
I'm in....
Paul, thanks for setting this up!!!
Also, i did not need the tires deflators as i have an ARB one, so he let me use some of that credit to apply towards the tree saver strap they carry. Unless you feel like wrapping a recovery strap 20 times around a tree, you need a tree strap!
is there a 24volt version?
Anthony.L said:The winch can be mounted anyway necessary. The ARB 03+ bumper for the 100-Series requires the winch to be mounted feet forward. It's the only option if you want a winch in that bumper.
At first glance I'm not seeing an easy way to clock the gearbox on this winch.
Cool...Putting you on the "commit to buy" list. We expect a detailed review after it's been trail tested by an 80s owner. You guys sure know how to beat the **** outta stuff.
