Did u get LT or P? I have the LT and have got used to the change.
...via IH8MUD app
'13 LC & '14 4R Trail
...via IH8MUD app
...via IH8MUD app
one of the big problems you run into with a wider tire on the factory wheels is the clearance on the UCA(would you be replacing those, I believe some of the after market ones allow for more clearance) I have the 275-70 R18's with no lift and the clearance between the UCA with the wheels turned is about a credit card width.. FYI all tires manufacturers are a bit different so sizes will vary...
I ran spacers for years on my 100 series, gave it a better looking stance and allowed for more clearance at the UCA's... But that was years ago, and the more research I have done on spacers the more I wonder if I want to run them on my 200 series?!?! They would accomplish exactly what I want, more clearance at the upper UCA and on the lower control arm, BUT lots of people say they are unsafe and cause heavy wear and tear on the bearings etc... I'm no expert on wheel spacers, just read some posts and articles that have cause me to pause on using them and try to find a better/safer alternative, i.e. after market UCA which would allow for more clearance or after market wheels... just my 2 centsI wonder how many people are running wheel spacers with wider tires. I ran 285/70/17's on my 4runner with Spidertrax spacers and my tires never rubbed the UCA. I'd eventually like to get a 2" lift as well with 285/70/18's too, so I'm wondering if spacers would do the trick on a LC.
So beings that I'm older and more worried about function/safety it gave me some pause!!! All that being said the 1.25 spacers pictured below would allow me to run a slightly wider tire and give me the clearance I need at the UCA... ATTACH=full]945396[/ATTACH]I ran these on my Tundra with almost no rubbing wiht a 2 inch lift, anyone running 285-75 R18's with a 2 inch OME lift on a 200 series??? I would love to try and make it work, even if I had to cut a bitI rolled Goodyear 285-75 R18's on my Tundra with the OME lift, I know it's a different rig, but just given you an idea of what might fit???View attachment 943805
I'm running 35mm h&r spacers with no issues at all. Suppliers confirmed that h&r release specific spacers for each vehicle and won't sell them unless they're sure they are safe and won't cause any damages to your vehicle. Marketing bs or truth i have no idea but they told me they would cover any damages if they were caused by the spacers.I ran these from Slee on my 100 series with no probs, but it seems as though the feelings toward wheel spacers in my area has gotten a bit more "harsh" in the past couple decades, i.e. some of the tire shops will not touch your rig if you have wheel spacers on your truckSo beings that I'm older and more worried about function/safety it gave me some pause!!! All that being said the 1.25 spacers pictured below would allow me to run a slightly wider tire and give me the clearance I need at the UCA... ATTACH=full]945396[/ATTACH]
Hello, I know this an old post, just looking to see what size Toyo's you went with. Looks good. thx!
