Tire Pressure recommendation
Gaijin,
This forum owes you a debt of gratitude... and a thank you cake or something. Football and boxing have left me incapable of basic math, and here you are in the clutch yet again.
I need the recommended pressures for a 2021 LC200 with LT285/65/r18 125/122Q Load Range E Yokohama Geolandar M/T g003’s.
First mud tire and I’m noobing it up.
Excellent question - looks like an interesting tire!
The RCTIP for those LT285/65R18/E 125/122Q tires on your 2021 LC200 is 42psi F/R.
HTH
Your tire description is incomplete, but I will assume you mean the LT275/70R18 125/122S Load Range E tires. If that assumption is correct, then:
The RCTIP for those LT275/70R18 tires on your LC200 is 41psi F/R.
HTH
Apologies. Yes, it is written as: M+S LT275/70R18 125/122S, Load Range E.
Maybe because my door label says to run at 33, the tire shop guy filled it 33.
Did a skim through this thread and wanted to confirm the recommended cold tire inflation pressure is 41PSI on a '21 LC200 for both of these tires?
BFG KO2: LT275 /70 R18 125R E1 RWL
Nitto Ridge Grappler: LT275 /70 R18 125Q E1 BSW
The RCTIP for ALL LT275/70R18 tires on your LC200 is indeed 41psi F/R.
So...
CONFIRMED 🍻
Can you please provide my the RCTIP for a 2021 LC HE with Toyo Open Country AT3 LT275/70/18 125/122 S BW ?
It never hurts to ask and be sure...
The RCTIP for ALL LT275/70R18 tires on an LC200 is indeed 41psi F/R.
HTH
May I ask the RCTIP sage about 285/65/18 Bridgestone Revo 3s on a 2013 Cruiser?
After insisting on 50psi, Costco sent me rolling at 39.
Many thanks.
Many thanks.
If you mean the LT285/65R18 125 Load Range E Bridgestone Dueler A/T Revo 3 tires on a LC200, then:
The RCTIP for those LT285/65R18 tires on your LC200 is 42psi F/R.
HTH
Calling Gaijin: Will you recommend the tire pressure for a:
Toyo ATIII LT275/65r18 113/110T C load id
Stock LC200
Thank you!!
Stock LC200
Thank you!!
Sure!
The RCTIP for those LT275/65R18 tires on your LC200 is 45psi F/R.
HTH
@gaijin recommended PSI for Michelin LTX AT2 275/65/R18 p-metric? Stock LC, normal load.
OK.
The RCTIP for those P275/65R18 114T tires on your LC200 is 33psi F/R.
HTH
May I ask the RCTIP for 35x11.50R17LT Toyo Open Country A/T III 118Q Load Range C - 2013 LX570
