Tire Pressure recommendation (3 Viewers)
Got it, thanks Gaijin. I checked and I have the 116T ISO Metric version. I will adjust to 29 today. Thank you!
Hello!
I was hoping for help in choosing my optimum tire pressure.
2020 HE
General Grabber ATX LT285/60/18 Load index 122, Speed range S, Load range E
THANK YOU!!!!
1. 2014 LX
2. Cooper Discoverer M+S 275/65 R18 (Not LT)
Thanks !
Hello!
2020 HE
THANK YOU!!!!
The Recommended Cold Tire Inflation Pressure for the General Grabber A/Tx LT285/60R18E 122S tires on your 2020 LC200 is 46psi F/R.
HTH
HTH
Thank you for the info!!!!
1. 2014 LX
Thanks !
Well... this is an interesting one. The Cooper Tire web site does not list the Discoverer M+S in this size (Cooper Discoverer M+S on Cooper Web Site ). Discount Tire only list the LT-Metric version (Cooper Discoverer LT275/65R18 at Discount Tire ) which does not give me the info I need for your size. Tire Rack does not list any Discoverer M+S tire in your size (Cooper tires on Tire Rack ).
As such, I cannot confirm any tire pressure recommendation.
If you look on your tire sidewall and can determine the following two three tire specs, I can give you a conditional recommendation:
1. Load Index (will be on the tire as something like "116T" "114" etc.)
2. Standard or Reinforced Load Rating (will be on the tire as "SL" "XL" "Reinforced" etc.)
3. Max Load at Max Inflation Pressure (will be on tire as "Maximum 2750LBS @ 45PSI" or similar
Without further info, I cannot proceed.
@gaijin now I'm curious about my tires. I've been reading through the thread and gotta ask. 2018 LC, Method race wheels, Falken Wildpeak AT3 LT285 65 R18
Curiosity is always good - and often rewarded!
The Recommended Cold Tire Inflation Pressure for the Wildpeak A/T3W LT285/65R18E 125/122S tires on your 2018 LC200 is 42psi F/R.
HTH
Yes, interesting that TireRack doesn't carry the Cooper Discoverer M+S.
Copper Discoverer M+S Studdable
275 /65 R18 116S SL - Max Load 2756 Lbs. Max Pressure 44 PSI
my local Discount Tire matched the DiscountTireDirect $, as you would expect, and ordered them in. They were $127 last week.
https://www.discounttiredirect.com/buy-tires/cooper-discoverer-m+s-studdable/p/27856
Thanks again.
Thanks again.
Great! Thanks for the info - all I need.
The Recommended Cold Tire Inflation Pressure for the 275/65R18 116S SL tires on your 2014 LX570 is 30psi F/R.
HTH
Gaijin,
Can you provide the RCTIP for:
2017 Land Cruiser
Nitto Ridge Grappler
LT295 /70 R18 129Q E1
Thank you!
Gaijin,
2017 Land Cruiser
Thank you!
Gladly!
The RCTIP for the LT295/70R18 tires on your 2017 LC200 is 35psi F/R.
HTH
Gladly!
HTH
It sure does help. Thank you so much!
Hi @gaijin!
Can you give me the pressure for a '13 LX570 running Nokian Hakkapeliitta R3 SUV in 285/60/18 116R XL? Also, is the pressure you give for GVWR loads or min weight?
Thanks!
Hi @gaijin!
Thanks!
The Recommended Cold Tire Inflation Pressure for ISO-Metric 285/60R18 116R XL tires on your 2013 LX570 is 34psi.
All my tire pressure recommendations are the same as the factory recommended pressure on the door placard - GVWR loads.
NOTE: The Nokian Hakkapelliitta R3 SUV 285/60R18 116R tire is NOT listed as XL-Rated on the Nokian site (Nokian Site), however, I have taken you at your word that your sidewall markings do indeed reflect an XL rating and I have recommended a pressure based on your description. Please be sure this is correct.
Greetings Gaijin,
I am running 40 psi in my Nokian Rotiva AT plus 285/70/17's load range D. Could you please tell me if this is correct? TIA!
Greetings Gaijin,
I don't know - too much confusion and too many unknowns :hmm:
You say you are running, "285/70/17's load range D" tires, but your picture shows LT285/70R17 - are you right or is the picture right?
There is no "Nokian Rotiva AT plus 285/70/17's load range D" tire listed on the Nokian site, only LT285/70R17 - are you right or is the Nokian site right?
Do you have a LC200 or an LX570? RCTIP is different depending on which you have.
So... help a brother out and lend some clarity to the situation.
TIA
TIA
Sorry for the lack of info. Yes LT 285/70R17, the picture is right. Running these on a 2020 LC HE. Thank you.
Then yes! The RCTIP for the LT285/70R17 tires on your 2020 LC200HE is 40psi Front/Rear.
HTH
Hi, gaijin.
Tried to find information in previous replies, but without result.
I'm wondering about RTCIP for my LC200 '08 tyres:
COMFORSER CF3000 285/70 R17 LT 121/118Q
NOKIAN HKPL LT3 285/70 R17 121/118Q
Thank you in advance.
