Thanks for the info!From earlier in the thread:
The Recommended Cold Tire Inflation Pressure for LT275/70R18 KO2's on your LC200 is 41psi F/R
I said lc200 and indicated p metric all in my first post in this thread with no edits. I merely gave an opinion on it seeming low, maybe I should have phrased it differently or whatever, good grief. Thanks.OK, "seems" like it's an opportune moment to highlight how important accurate descriptions of tire size/construction (P-Metric, ISO-Metric, LT-Metric) and application (i.e. LC200 or LX570) are to determining correct RCTIP (Recommended Cold Tire Inflation Pressure).
Let's focus on a common tire dimension and see how construction and application affect RCTIP:
P-Metric P285/70R17 - LC200 = 27psi / LX570 = 26psi
LT-Metric LT285/70R17 - LC200 = 40psi / LX570 = 35psi
ISO-Metric 285/70R17 117T SL - LC200 = 32psi / LX570 = 29psi
So... if the only info I get is something like, "what's the pressure for 285/70R17?" I really don't know what to suggest - could be anything from 26psi - 40psi.
If you want a RCTIP for a P-Metric tire, please include the "P" in the tire description.
If you want a RCTIP for a LT-Metric tire, please include the "LT" in the tire description.
If you want a RCTIP for an ISO-Metric tire, please include the Load Index (e.g. 117) and whether the tire is Standard Load (SL) or Extra Load (XL or Reinforced).
Also, it is important to know whether you are using the tires on a LC200 or LX570.
I don't mind helping out with RCTIP recommendations, but please, give me the info I need to get you the correct answer.
HTH
Well... I find science trumps feelings every time.
On your LC200, the stock P285/60R18 tires at the factory RCTIP 33psi have a Load Limit of 2512 lbs.
On your LC200, the P285/70R17 Wildpeak A/T3W tires at my RCTIP 27psi have a Load Limit of 2527 lbs.
Seems perfect to me![]()
HTH
Ah it’s cool. I wish I knew how you did this formula and read the thread and the PDF but still don’t seem to get it. The hot dogs at discount tire had them at 38psi and one was at 45. I put all ofThat particular post was for general info - not directed at you personally. Sorry if you took it that way, that certainly was not my intention.
My earlier post, however, was in answer to your comment about my RCTIP seeming low:
@gaijin can you help with with a RCTIP for my 2007 Sequoia? P265/70R17 Wildpeak A/T3W tires. I am running them at 38psi.
Thank you!
Hi sir, what is the RCTIP for 2008 stock LC with toyo proxes st3 285/50/20 116V. Thanks
What is recommended pressure for Nitto Terra Grappler G2s in LT285/65/18? 2020 LC HE. Thank you in advance!
I bet this was asked before, but if it wasn't what is the recommended cold tire pressure for BFG KO2 285/65R18 for 2010 LX 570?
I was told 37psi.
LT. 285/65R18 BFG OWL 4S HI All-Terrain T/A KO2 10PlyWhether @LXCruza has P metric, LT, etc. tires that pressure recommendation could change. Basically, more info is needed from LXCruza before a good recommendation can be given.
2018 LC
LT285/65R x 18 KO2, 125 / 122R Load range E
Thank you!
