Tire Pressure recommendation (2 Viewers)
@gaijin, lets pretend that there is a 2018 LX570 running LT305/55R20/E 121/118S Falken Wildpeak A/T3W tires, and that it weighed 7600 lbs. What would the recommended pressure be?
What about at 8,000 and 8,500 lbs?
Thanks!
Thanks!
I addressed this in the past. I do not give recommendations for anything over the GVWR of the vehicle.
It is unwise to believe that simply by addressing the tire pressure, one can somehow magically increase the capacities of axles, brakes, shocks, springs, gears, transmission, or any individual component of the suspension and/or drive train.
So, the RCTIP for your hypothetical 2018 LX570 running LT305/55R20/E 121/118S Falken Wildpeak A/T3W tires is 36psi F/R. That is good for all vehicle weights up to and including the GVWR of 7,385 LBS.
HTH
Going to take a wild guess, Falken Wildpeak AT/3W in LT285/70R17 E/10. The correct inflation is 40PSI F/R cold
And... you would be wrong - that is, if you mean for use on your LX570. You would be correct for an LC200, however.
The RCTIP for the LT285/70R17 tires on your LX570 is 35psi F/R.
HTH
Gaijin, Riddle me why? I don't understand why the 200 in LX trim is different than a 200 LC trim.
Here’s his answer from one page back:
The simple answer is because the LX570 has a different suspension system than the LC200. Tires play an important role in the operation of the suspension system. Toyota engineers have chosen different tire Load Limit requirements not only to adequately handle the load, but also to provide the desired tire spring rate to optimize performance of the entire system.
HTH
Roger that, is the only thing I could think of with the LX but really surprising it is that significant of a difference.
I'm confused about something. What would the RCTIP for LT285/70R17 D 121 Q in an LX be? Do I have to divide the OEM load by 1.1 for this tire?
Short answer is the RCTIP for LT285/70R17 on an LX570 is 35psi F/R.
Slightly longer answer:
OEM Load Limit for P285/50R20 @ 33psi = 2,315 Lbs
Since going to an LT-Metric tire from a P-Metric tire, 2315 / 1.1 = 2,105 Lbs
Required psi to reach 2,105 Lbs with an LT285/70R17 is 35psi.
Find Load/Inflation tables here for verification: Guidelines for the Application of Load and Inflation Tables
HTH
gaijin,
Thank you for providing this information to the forum. What pressure is recommended for BFG All-Terrain KO2 LT275/55R20, load range D (115S), on 20x9 rims for a 2016 LC (stock)?
Also, would the recommended pressures change when towing a 4,500lb trailer or 7,500lb trailer?
Thanks in advance for your help.
gaijin,
The RCTIP (Recommended Cold Tire Inflation Pressure) for the LT275/55R20/D 115/112S BFG All Te3rrain T/A KO2 tires on your 2016 LC200 (NOT LX570) is 51psi F/R.
That RCTIP is good for all weights up to the vehicle/trailer/tongue limits set by Toyota.
HTH
What would you recommend for Nitto terra grappler G2 305/60/18 116S XL?
Thanks
Beats me. Are you putting them on a LC200 or LX570?
