I hope I'm asking this correctly. How many times do the camshafts spin per one time the distributor rotor spins?
So here's what happened. Last Saturday I (with some help) changed the dizzy o-ring. Took the valve cover off, got everything at dead center 0 degrees on the balancer, and lined the notches on the distributor. Put everything back together and fired up.
Checked the timing and it was retard (in the negatives). Adjusting the distributor barely moved it to 0 degrees.
Not wanting to take the valve cover off, we lined back up at 0 degrees and took the distributor off (not thinking) then realized the rotor was in the 5-6'oclock. rotated the balancer 360 degrees back to 0, checked the #1 piston was up and re-did the distributor. Got the timing where it needed to be (engine stumbled a little, but its been having a stumble lately). Attempted to jump the ports but while pretending liking im working, read a few threads and im sure we jumped incorrectly.
This morning, went out to warm up the LC and there was a weird noise. I figured it was just COLD. Came back 10 mins later and the CEL was on saying multiple misfires. So im asking above to see if i need to give another spin to the balancer, or do I need to jump ports correctly (or both), or what?
Note: reading this back to myself, im sure we spin the balancer/cams to the right position, but imma let it ride because I still might be wrong. Thanks for the help, and don't roast me too hard ; p
in the LC so I'm slowly going to have to get inside of everything and replace with gaskets. Anyway, we opened the distributor, razor'd off the FIPG and the "o-ring" crumbled.
