- Joined
- Jan 6, 2012
- Threads
- 342
- Messages
- 11,017
- Thread starter
- #21
I guess one of my issues is trying to squeeze every bit of juice out of it. Eventually you reach the point where thats all their is, I think I am approaching that point, but from what I know of the stock timing curve, I was curious how much people were setting their initial advance with a stock setup and their experiences with such. That would give me insight in how much advance the 2f can handle. The timing curve is a huge part of getting the most power out of it. I think my peak timing is just about right, I have a feeling the timing curve though needs to be steeper initially from 1000 to 2000 rpm than I have it and I may be able to get a little more juice out if it.I used to have a tbi setup . I ran it for over a decade . It had a knock sensor , I insulated it from the block with a piece of rubber as per an article I read at some point . Over the years it ran really well , never left me stranded on the trail but it never really ran perfectly all of the time . I did have a speed sensor hooked up for a while and it didn't help . I never really got into tuning the prom or ecm . It seemed to run well enough for me not to bother trying to get every little wild hair that happened occasionally . Most of the issues I had were from running an HEI distributor . It used to chew up the magnetic pickup inside occasionally . I tried different distributors (toyota electronic) over the years and they never ran as well as it did with the DUI unit . From my understanding , the ecm controls the amount of advance by using the knock sensor in relation to retard the timing . 15 degrees is its capability iirc. If you don't have a knock sensor , you will have a trouble code and it won't run closed loop (all sensors responding as they should) FWIW I used to run my timing anywhere from 12 to 18 degrees via timing gun with the spout wore unplugged . Most of the time closer to 12 . I have since moved on and now run a 3fe . It is all toyota and runs better than it ever did with a TBI .
