- Thread starter
- #41
No they were well clear of the radius arms. I’m not afraid to grind if need be. I’m pretty sure I have enough caster correction. Will find out for sure after the tie rod goes on and I get an alignment.Holy heavy duty! 1.5" x .375 wall?? That's an extra fat tie rod. If your old rod was in close proximity to your radius arms, this one may force you to grind on the arms for tie rod clearance. This assumes that you have installed adequate castor correction for your lift. I had to grind on my arms, no biggie and they are still in one piece.
