I need to replace a relay rod end found to be loose during an annual state safety inspection.
A quick call to Cruiser Outfitters and I had the parts in hand in a couple of days.
I got the relay rod off the vehicle and the pitman arm rod end came out fine with a little kroil and a pipe wrench (very little force), but the ofher end is seized solid.
I tried kroil, heat, tapping, large pipe wrenches, etc., but all I've managed to do is gouge the shaft where I had it clamped in the vice.
So, I guess it is new relay rod time (and maybe a matching tie rod while I'm at it).
Are Slee and Budbuilt the main upgrade options? Budbuilt has the typical wait time. Looks like Front Range has an offering, but it has oversized threads? I already have a full set of 555 tie rod/relay rod ends from Cruiser Outfitters on hand. Marlin crawler is out of stock.
OEM seems available too, but for the price I can get an upgraded part for less.
Any options I'm missing?
This will be used offroad extensively and will bounce off rocks, in case that matters.
Any other advice?
Any other advice?
