Thoughts on these 60 interior Panels?? (3 Viewers)
WSOPgold2012
MoxieMan
Front Range
www.orikawa.net
4 doors: $749
  • PRODUCT INFORMATION​
    • All Aluminum Construction
    • Speaker Ready
    • PALS Standard Attachment Points
    • Inner Window Felt Replacement Included
    • OEM Color Matched Powder Coat
  • TECHNICAL SPECIFICATIONS​
    Front Door Panel
    • 4" Speaker Ready via 3.75" Cutout
      • 2" Maximum Recommended Speaker Top Mount Depth
    • Die Pressed Reinforcement Features
    • 5x5 PALS Standard Mounts for most large MOLLE pouches
    • 2mm 5052 Aluminum for Low Weight and Corrosion Resistance
    • Window Felt / Belt Weatherstrip replaces Toyota 68170-90A01
      Rear Door Panel
    • 6.5" Speaker Ready via 5.75" Cutout
      • 2.25" Maximum Recommended Speaker Top Mount Depth
    • 2x2 PALS Standard Mounts for most small MOLLE pouches
    • Window Felt / Belt Weatherstrip replaces Toyota 68190-90A01
Rear Panel" $699
    Two Latching Hinged Access Doors
    Fully Sealed SBR Weatherstripping
    Two Piece Design: Quarter Storage and Front Trim Cover
    • FJ62 install re-uses factory rear seatbelt trim cover
    3mm 5052 Aluminum for Durability
    Hinged Access Doors for Storage and Maintenance
    Takigen Push-to-Close Aluminum Latches
    Sunco Mounting Hardware Made in Japan
    OEM Color Matched Powder Coat by Cardinal
    SBR Rubber Seals for Door and Panel
    Rubber Well-Nuts for OEM mounting - no modification required
Tailgate: $549
    Replaces OEM Tailgate Trim with Access Panel
    * product cannot be installed on OEM tailgate without permanent modification to tailgate. Instructions provided for necessary alteration.
    • Two Latching Hinged Access Doors
    • Fully Sealed SBR Weatherstripping
    • 3mm 5052 Aluminum for Durability
    • Hinged Access Doors for Storage and Maintenance
    • Takigen Push-to-Close Aluminum Latches
    • Sunco Mounting Hardware Made in Japan
    • OEM Color Matched Powder Coat by Cardinal
    • SBR Rubber Seals for Door and Frame
    • Machined Door Flange for 270* Support
Those look pretty nice. Wish they came in a dark brown, although I guess you could get them painted/coated in whatever color you want. Wonder if you can buy them in bare aluminum?
@CenTXFJ60 installed a set recently
I really like them. The dark brown would match the OEM ones. Spenser may ship a bare set or do a different color if you inquire with him.
I wonder if you could ID the coating on that rear seat carpet rail and use that as the FJ62 brown?
That seat back rail is not a good match to the Toyota color. I just used a brown rattle can I had on the shelf. Glad to post a pic of the color if you’d like it
Hey what's up everyone!
Send me a message if you have any questions for sure. I will be modifying the door cards to fit 62 ASAP. 80 tailgate, and some 1st gen truck panels too.
The quarters fit the 62 currently since they're 2-piece the front section doesn't need to be installed and drops right in with the 62 seat belt retractor trim in place.
One of the early customers stripped his tan door set and is doing the dark brown... im skeptical but we will see when they're done.
The point of the colors is to match the lower dash metal and it looks very factory that way.
Speaker cut outs are to accommodate common 3 way speaker sets... 90% of those fit depth wise and are tweeter, 3.5" and 6.5". Tweeter can be put anywhere without corrosion issues on the panels.
Just send me a message and we can figure out if it's something you'd like to do. Cost and time add up though you know with powder coaters these days
