thanks. the dealer gave me part number 9091603052 but couldn't tell me if it was a 190 deg thermostat. would you know if this is the correct one.cant get heater to blow hot air. heater core is not clogged and we replaced the water pump and new thermostat but my mechanic is asking if there should be a different thermostat then what oreillys sold us
i better check that. thanksThere's an o-ring between the thermostat and the top of the housing. Is the radiator getting hot?
aweosome, thanks I will get it ordered.Officially in the USA there is only one thermostat available from Toyota for the FJ60...the 190°.
Yes that is the correct PN.
The 180° thermostat was meant to be used on a different vehicle, but some guys use it on the 60.
1980 FJ40 and earlier with 2F gas engine got the 180º F thermostat (82ºC)
PN: 90916-03048
1981 and later Cruisers with 2F gas engine got the 190ºF thermostat (88ºC)
PN: 90916-03052
(info above provided by @FJ40Jim on one of his posts)
