I get uncomfortably high temperatures in the passenger foot well. I pulled out all the carpet and am planning to replace the jute backing with new 40oz jute. What else do you recommend for insulation? I care much more about reducing heat than noise.
In other threads I've seen people mention Heatwave Pro, Thermozite, and Reflectix. Any real-world experience?
Also, anyone used secondary heat shields or insulation on the cats or transmission tunnel (outside on the body)?
I did mine for sound proofing but have been please with insulation effects:
I followed the rec's from Sound Deadener Showdown (no longer in business), archived here if interested.
Sound Deadener Showdown | Your Vehicle Quiet - https://web.archive.org/web/20210609214849/https://www.sounddeadenershowdown.com/
Quick summary:
1. CDl tiles - this is for sound deadening so could skip it. The stock already has some of this but adding more helps.
2. layer of Mass loaded Vinyl - get one known to not smell like from here
soundsulate 1lb Mass Loaded Vinyl 4' x 25', 100 sf roll, Soundproofing, MLV 739027503552 | eBay - https://www.ebay.com/itm/Soundsulate-1lb-Mass-Loaded-Vinyl-4-x-25-100-sf-roll-Soundproofing-MLV-/121596772331
You could probably go with thinner than 1/8 - you use HH-66 Vinyl Contact Cement to glue it all together
www.amazon.com/gp/product/B00BUB5JOA/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
3. MLV needs a decoupler- so use this or equivalent Second Skin Mega Zorbe Melamine Foam Sheet
www.amazon.com/MegaZorbe-Hydrophobic-Melamine-Foam-Stick/dp/B01N2497HN?th=1
If you were to skip a step it would be this one but if you go to the effort of MLV this is easy.
4. cover the MLV with this 'undercarpet' (Design Engineering 050113 Under Carpet Lite Sound Absorption and Insulation). This would in place of the jute. I bought a new OEM carpet set and left the stock jute on it.
www.amazon.com/Design-Engineering-050113-Absorption-Insulation/dp/B008NF84J8/?_encoding=UTF8&pd_rd_w=FHw1J&pf_rd_p=09c27161-2df3-4bce-95e3-5a30d05d01d6&pf_rd_r=F3TVEV3N269BGSCQJ39A&pd_rd_r=dc9e7396-1067-4b19-909a-082c46ac4e4f&pd_rd_wg=7G68Y&ref_=pd_gw_ci_mcx_mr_hp_atf_m
then carpet over .This step is not in the Sound Deadener Showdown list. My son did this to his truck as an extra layer and I was pleased with the cost/effort benefit. I went back and added it where I could. It gets thick so it can't happen everywhere (i.e. under the gas pedal) and under certain trim areas.
5. for ceiling - either use the 'undercarpet' if you can get that to adhere between roof underside and put the headliner back on. I used a foam similar to this
Neoprene High Quality Foam Sheets - https://www.foambymail.com/NE-HQ/neoprene-high-quality-foam-sheets.html
for sound but it has insulation properties. The foam was good enough and easy to install with a glue gun.
It's a chunk of work - all of this for the entire vehicle, but I was doing a full stereo rewire, backup camera, etc and fixed a bunch of little things here and there (bulbs and broken plastic things) - it made it really easy to do all this while it was gutted. And cleaned everything.
edit: For just the passenger footwell this wouldn't be that hard of a job and just order enough of what you'd need. There's probably a smaller about of MLV somewhere on-line. The passenger side was easy to make it thick with this triple layer of stuff.
