Question on tubing flaring someone might be able to help with. Do I need to find a metric double flare tool? Or can I get by with a standard one?
Broke out a tool I picked up a year or more ago and found it's standard. Tried making a flare for the clutch line using the 3/16" die (tubing seems to spec out at 4.75mm or 3/16" OD) but it didn't seal. Now it's likely that this first try was crappy on my part, but the "nub" on the die is a very loose fit inside the tubing, doesn't seem right... Will likely give it a second try tonight, along with getting started on some exhaust from the manifolds back to O2 sensors.
