The Moonshine Motel (2 Viewers)
Big difference. Looks great. Can't wait to see the windows in.
Ask and ye shall receive. Windows installed.
Looking forward to being jealous at GSMTR.
Trim finished and dot tape applied. Exterior is 99% done now
Some fun facts:
-estimated 14 sheets of siding, bought 20, used 18
-estimated 1000 screws, bought 1250, used 1241
-estimated 7 pieces of lower trim, bought 8, used 6.5
Lesson? Always buy more than you estimate you'll need.
Dude, that is so badass!! I love it. Especially knowing you have 9 spare screws.
That leaves 2 for each tire, and 1 for the spare, right?
I fricking hope not. $900 for 5 trailer tires :eek: 6 months ago the same tires would have cost ~450-500.
Everything is expensive now.
Wow this looks great and loads of progress!
Trailer wiring is boring, but necessary. New 7-pin and box, new breakaway battery and switch. Running all new wires for the brakes tomorrow.
When does the stripper pole for the AdamExpress get put in? @custyota
New wheels and tires, then a bit more wiring today. Elected to make a run for the passenger side brakes, then another for the driver side brakes. Should make troubleshooting easier should it ever happen. Bought a 100' spool of 10ga anchor duplex jacketed wire, so it made sense to burn the wire now. Future me should be grateful.
Edit: finished up the brake wiring also.
Have some wire questions for you…adding brakes and rewiring boat trailer. Catch up with you one evening maybe.
Ask me after I verify all this stuff works as it should, lol.
Wiring all works. That junction box made it easy and clean.
Put in a small extension to the rear light harness to fit the rear tie down points in the spot I wanted. Worked out great.
Glued on some bogey wheels, and painted the inner bits of framework I wanted to.
Laura painted the bottom of the floor sheets (3/4" treated ply), then I got them cut and in place. Cutting out for the in-floor tie downs was tricky, and I messed up the front sheet. Not a huge deal to patch, but still a rookie move.
Retained the fresh water tank left/right with some floor cutoffs screwed in.
Need one more sheet (6 total) because of the odd floor crossmember spacing around the tanks.
Feels good to have a floor.
Another big day today. Main floor fitted with hidden storage compartment, goose area stripped, cleaned, painted, and floor put down. Two layers of 3/8" ply with 2" eps foam sandwiched between. Headboard got a sheet of aluminum to shield against genny heat, 2" eps foam, and one layer of 3/8" ply.
Nearly there now boys. Nearly there.
