Just a recap for newbs (like myself) to show progression....bought mall cruiser from under a tree up by Lebanon, OR. Grandmas backup needed some attention. All stock and driven:not maintained.
Baseline to date-
Crankshaft seal
Dizzy oring
oil pump oring
New Aisan water pump
New oem belts
new Toyota intake assy
New koyo 2 row
New plugs
Diffs serviced with all new Castrol
Switched to Delvac
New rear rotors and calipers
Falken Wild Country ×5
Hella 500 amber
CREE plug and play LED headlights low/high
CREE 12 in helper
Rear lens cover guards (damage mulitpliers)-REMOVED-
"Custom" rear tire swing down -modified Bonarue welded to crossmember
Full stereo stuff-6.5's in all 4 doors and bazooka tube with BT HU
OEM roof rack delete with stainless roof rack gutter mounted addition (bedlined)
OME 851 front OME 866 rear -tokicos all around......cant decide on upgrades
Wagon gear FM/CB mod , whip
Wet okole covers up front
Crappy Sleeping platform with d rings
And my fav mod.....the wire shelf mod via home depot
Shaky mirror done
New front wheel bearings
Caster correction washer mod
Silicone PHH constant Tq
New Koyo 1918- again-FAIL#2
OME Steering damper
New Gates upper and lower radiatior hoses
8k winch up front
New Power steering pump
New PS lines
New CSF radiator- this is something I can do asleep now
TG sliders
Aussie rear locker
Front axle overhaul-birfs all pretty now
All new tie rod ends
Rear bumper DIY- in progress
30mm MAF Front coil spacer- stink bug be gone!
Bilstein 5100's
NWTI Rear Bumper DIY
Tuffy Console 013
Before-
Baseline to date-
Crankshaft seal
Dizzy oring
oil pump oring
New oem belts
New koyo 2 row
New plugs
Switched to Delvac
Hella 500 amber
CREE 12 in helper
Shaky mirror done
OME Steering damper
8k winch up front
New PS lines
TG sliders
Aussie rear locker
Bilstein 5100's
Tuffy Console 013
Before-
