The KSA Project
Radiator Flushing Update
Date​
Description​
Discharge Fluid​
Fluid Added​
6​
5-01-2023​
6th Flush​
WaterRadiator Cleaner & Fresh Water
7​
13-01-2023​
7th Flush​
Radiator Cleaner & WaterFresh Water
8​
21-01-2023​
8th Flush​
Fresh WaterRadiator Cleaner & Water
9​
28-01-2023​
9th Flush​
Radiator Cleaner & WaterRadiator Cleaner & Water
10​
4-02-2023​
10th Flush - FINAL​
Radiator Cleaner & WaterRadiator Coolant
After 10 flushes, I've given up; thinking that's the best for now. Replaced the old hoses with silicon hoses and installed new washer / reservoir tanks. Also got a new OEM radiator cap cause the old one was leaking.
I removed the old power steering pump (it didn't work). Had a replacement, but noticed the bracket was different. On the old pump, there is only 2 bolts, with one extending to both sides of the bracket where there is a threaded hole to hold it. The newer pump has 3 bolts and the bracket holes are all threaded. Need to source a bracket.
Ordered / got a new clutch plate, c/w pressure plate & master / slave cylinders from CCOT. Not my best idea....shipping costs killed me!! I not sure I needed it.
Got the mechanic to replace it along with 2 broken lug nut studs. He re-surfaced the fly wheel too. Replacing the stubs meant loosening the brakes....which meant when he was done...well...the brakes were soft and not balanced. Went back the following weekend to fix that, noticed I was having fuel problems.
When running at consent speed, say 60 kph, I feel as if the cruiser is struggling to stay steady. The engine was jerking. It also happens at slow speeds, if I'm on 2 driving around the parking lot. Mechanic says its the fuel pump; but I've lost confidence in this mechanic.
I'm out of time, I'm packing up to go to Toronto, with my "new" toy. Will get the Mechanic to replace the fuel pump, its relativity cheap here and also change the fuel hoses and will try to flush / clean the tank before. I just hope there are no more surprises. I know with a 40-old classic...there are always surprises, but would like to just be able to drive it down the street in peace.
April Update
March was crazy busy, but took another chance with another mechanic recommended by a friend. Issue appears to the setting / adjusting the timing to match the engine. Thankfully, this mechanic did a better job; but am not fully satisfied. Starts up perfectly but at the top of 2nd gear; when is rev'ed up it feels as if the brakes are suddenly on. This is way above my comfort zone, did some reading / research and my understanding is that the distributor is now set on advanced setting. Re-setting it might reduce that hesitation but would have impact on other gears. All others appear ok so really dont want to mess with it again. But would really like some advice.
But was out of time...as it was time to pack ...
Strapped in and off to Toronto!!!
Container arrived in Toronto early June 2023; unfortunately my Customs Clearing agent could not get their act together. At the end, had to go to Canadian Customs and cleared my container in a matter of hours. CBSA was great, but it still got stuck with demurrage charges!!
After paying up ...i was not able to go personally to supervise the removal of the vehicle due to work commitments. BIG Mistake!!
:censor::mad::bang:
After I finished cursing / crying... took stock of the situation. Plus points was no one was physically injured, damage was superficial; ie it was body work only. The Owner of the facility took full ownership and offered to buy /paint replacement parts.
I needed :
  1. Front Fender
  2. Chrome Bumper
  3. Turing Light
  4. Driver's Side Mirror
I gave up the part numbers, and directed him to SOR.com. He ordered the parts.
In the meantime, my Saudi mistress was finally home...
That's the original Qatari Beast (FJ45).
Managed to remove the old fender ... but had to cut a bolt (it was bolted to a welded nut in the frame...but the welds broke and the nut was spinning).
Since I got clear access, also decided to change the rubber hose on the power steering tube. Looked like it was baked for 40 years. eventually, had to cut / rip it off. The power steering does not work, but thought it would be good to replace the rubber.
Will fix the fender next weekend.
Nice thread and great work @AYM707 . What was the original paint code for your 40s from Riyadh? I would be interested to know more details about your shipping from Riyadh to Toronto so will DM. Thanks mate.
Haven't posted in a long time...
I got a replacement fender, bumper, & turning light from SOR. Took me 3-4 attempts to finally get it installed correctly. At the end, had to cut some bits off and drill some additional holes. Its not a perfect fit; which was disappointing.
I used rubber foam to block / hide the gap between the front bib and the fender side wall. Just noticed the gap b/w the side apron and the fender :frown:.
I still need to get it painted to match....but it was enough to get my plates!!! I'm now road legal.
Does any need / want an original dented left fender?
Haven't updated this thread for a while. To be fair, haven't done much with the vehicle over winter.
But, when I flushed the radiator & changed the hoses in KSA, I forgot to replace the hose between the engine cooler to the pump. The one on the very bottom. I also knew there were some pin prick holes on the radiator, so decided to finally do that. Drained the system and pulled the radiator. I got some brass plumbing fittings (3/8" MIP & 3/8" FIPx 3/8" FIP) from Home Depot; and replaced the plastic cock at the bottom. I'm sick of being soaked in coolant trying to open the drain. Just welded the brass fittings and pressure tested the radiator. Replaced the hose.
Pulled out the thermostat housing, for a cleaning. Added new gaskets. Tightened the screws......and broke the housing! :bang: It must have had a hairline crack in from earlier (That's the story...and I'm going with it). Rushed to NAPA and got a high temperature bonding putty. I was not very sure about it; but it was a JB Weld product; so thought it would work. Applied and let it cure for a day. Then applied a healthy layer of high temp silicone over the crack area and bolted everything up. Not to tight this time. Filled her with water, just to check for any leaks. Fired her up and no leaks!!
I'll drain the water in a few days and fill it up with coolant.
2025-02-13 Update
To be fair, I really have not spent any time on my FJ40; mainly working on the FJ45. I need to get it out.
I did shop around to get a price on painting the fender. Most people advised on removing the part than painting it. That's my first task, whenever the FJ45 goes.
But I did take out the original radiator, so that I could install it on the FJ45. (long story...read it here ....https://forum.ih8mud.com/threads/radiator-boiling-over.1343096/) . I managed to get a 3-row AL radiator on e-bay. I wish I checked the bolts hole alignment against the old radiator, before installing & connecting all the hoses. I did get 3 bolts in; so its secure for now. Flushed / burped the system.
