Builds The honey badger build
I have some of those
I used six if I remember correctly, been awhile since I needed it. Never had a problem with them outside of being made of aluminum ( easy to strip the threads).
I used the alum power tank roll bar mounts. Is Elsie riding shotgun or dog bed in the back ?
You may not see us Tues/Wed as my run count has dropped to 1 and we may go in Tahoe side.
No she rides in the back. Wow you have a large group.
So I have a question about your build if I may; I saw pictures on the previous page of how your rear shock was at an angle - I’m studying and trying to learn in preparation of linking my 4 door build, and I was toying with the idea of leaning the shock but keeping the spring vertical over the rear axle.
I did go back clear through this thread but didn’t see a detailed process of how the rear coilovers were mounted, maybe I missed it.
Is there an advantage to angling a coilover vs using a separate shock and spring?
What are the consequences of leaning the whole thing, as far as ride, travel, and engineering the link suspension?
Your truck looks awesome, BTW!
My rear upper mounts tie into my cage . Really the reason for the angle is packaging . I did not want to cut into the tub . If you are running just coils then you want to keep them vertical . I do not remember off the top of my head ? but when a shock is at a angle you lose a percentage of its damping ability . Most of the builds i have seen they are running 2.0 coilovers. i run 2.5 so thats a little different as well . I do want to get my fronts revalved because i originally had triple bipass shocks to run with it also but i just could not get them to fit . So my fronts are a bit soft . . The blue 40 i am building had Coils at one point and it was really flexy but the coils will fall out so you have to run limit straps . I can say my 40 rides really nice and i never expected to drive it on the street but it drives straight and 1 finger on the wheel . I have a buddy with another 40 also on 40s but he has a LS in his and last summer we were kinda racing i guess you could call it for some turtles . and were doing over 80 and it drove fine . ( my 40 would pull away from his ) and that was with my crappy sniper . now i know it will pull his .
Here are a few pics. So you can see from the top the plate it part of my cage then from the bottom it ties to my frame
I had to notch my frame in addition to cutting into the tub to vertically position my 2.0 coilovers. They wouldn’t clear the frame had I not done this. You may have better luck with a shorter coil and separate shock setup. I like Jeff’s setup.
This is kinda why I was asking. I’d like to not have to cut into that aqualu tub, I’d like to put the jump seats in it. But I’m close to being able to doing a vertical coilover, if I compromise on travel a bit.
In my mind with just a short spring, the leverage from the coil torquing the frame is much less, compared to really tall buckets.
That looks amazing, very innovative.
I had missed you didn’t even have to build a “bucket” for the shock mount.
I had seen how you tied the cage into the frame and I really liked that idea, allowing about as much cage movement as the body mounts allow.
Your mig welds look better than a lot of tigs.
Thanks for the pictures and explanation.
Angle will help with stability to some degree. It can help with some body roll as well. A lot of that comes down to link geometry through. I have nearly 30° of rear coilover angle, but it handles very well without a ton of body roll.
An increased angle will change shock valving characteristics to some degree, but its usually not super noticable inless you are on a super high perfoming setup.
Thanks.
First time, I bet I’m not building a super high performing setup :)
But I’m gonna give in a go, I just hope it’s decent on the street to get me to where I can find it’s limitations off road.
Really appreciate your build thread, Got mired down in the cage section, haven’t even found the suspension part yet but I will!!
Your welds are freaking inspirational.
Thanks! I'm lucky to be able to learn from some really great fabricators. My rear suspension stuff starts around page 50 on my thread, I think.
Sometimes you just have to laugh at yourself 😃. So when I painted my fenders way back when. I told the guy what color black I wanted . I also told him just single stage . Well I painted them and they looked good but never as shiny as my hood and stuff but close after I wet sanded and polished. Well I went and got some more paint to spray my top. And I asked what ratio to mix as it’s been about a year I guess I forgot . He said 2 to 1. I said how much hardner. Ohh. You don’t need hardner with base . Ok Well I sprayed last night and they looked good but still a bit duller 🤔. Then it hit me ahhh this is base clear 🤦🏻‍♂️🤦🏻‍♂️. So this morning I went and asked to be sure. Yep . So I got a gal of clear and Now we are cooking . Why I never caught this 🤷‍♂️it’s just been one of those years. So I am pulling my fenders and respray 😃
