The Great ONSC Gun Thread (1 Viewer)
The sight pictured does not have the correct mounting points for a Model 88.
This is a supplier that I have used to purchase apertures for my Redfields, in multiple aperture diameters. I have found this helpful in tailoring the sight picture to target size and ranges. Since he carries some apertures for Williams, there might be some of interest to you.
I need the entire sight assembly, not just the thread-in eyepiece.
Random DIY tech, but the HF kneeling pad ($5) fits their Apache 4800 case ($40) pretty snug on width. You can cut it with a utility knife. Here's what I did with mine. Holds my pistol collection much more securely than the standard pick-n-pull foam.
I am not a fan of the pick-n-pull foam either for my cases. I opted for large sheets of foam from Amazon.
Set the pick-n-pull aside after using it as general template, then cut amazon sheets for exact fit.
Also, the Amazon sheets were layered in build up, so I cut along layer lines to tailor the depth too for to refine the fitment.
I am satisfied the costs and results.
Possibly too much information and detail ...
The foam in this case is fitted so I can carry a combination of Winchester 52C/D, Remington 40XB or H&R M12. They are all match rifles with Redfield sights so I used common features to define generic outline that they all fit within. So I can mix and match based on what I want to take to the range on a particular day.
The foam in this case is tailored similarly to my match rifles with scopes or my CZ for NRL22 competitions. This case is from the CMP and was sized for a Garand so it is a little short for the match rifles at 52 inches in length. Hence, the value for the fitted foam with a tight case.
Drooooooooooolllllllll!!!!!
7PRC. Defiance anTI-X action. MDT chassis. TriggerTech trigger. Outlier fluted barrel. Surefire suppressor and mount. Arken EP-5 5-25x scope. Finished assembly today. Next up: sight it in.
nice build! What's your goal (competition/elk/or what)? You likely already know, but your POI will shift with vs without the can. I'm guessing you are planning on leaving that attached. Socom762-Ti? I am a fan of FDE frames too! Pretty much anything other than black when possible.
I plan on hunting with it and playing at shooting long distances. I will probably always shoot it suppressed. The suppressor is the regular 762 rather than a ti version.
