The Diesel Part number thread. NO CHIT CHAT or PARTS # REQUESTS! (1 Viewer)
BC, Canada
Website
bcfishingreports.com
Same idea here.
Please list the part number and it's application on any part that you may have used for your rig in the past.
Stone
[size=+2]PLEASE ONLY POST PART NUMBERS IN THIS THREAD. CHECK PREVIOUS REPLIES TO AVOID DOUBLE-POSTING. IF YOU HAVE QUESTIONS REGARDING PART NUMBERS, PLEASE START ANOTHER THREAD. THIS THREAD WILL BE CLEANED UP OF CHIT-CHAT AND POST NOT OFFERING NEW PART NUMBERS. THANKS.[/SIZE]
[size=+1]B,2B,3B,13B-T OR ANY OTHER B DESIGNATED[/SIZE]
NAPA Gold/WIX numbers:
Oil Filter - NGF 1515MP (Cross reference to a Fram PH8A).
Fuel Filter - NGF 3393 (May use NGF 3386 for a 3B).
Air Filter - NGF 2159.
Toyota part numbers:
Thermostat: 90916-03103.
Thermostat Gasket: 16341-56021.
Toyota Part numbers:
Exhaust Manifold Gasket: 17173-58010.
Exhaust Manifold Stud (Long with Torx drive end): 90116-10150.
Exhaust Manifold Stud (Short with plain end): 90116-10149.
Exhaust Manifold Nut: 90179-10010.
3B BJ60
Block Heater C0140-00126-S2 oem
Alt Brushes 12v 021630-0530 Denso
Volt reg 12v IN218 Transpo
Steering Column U-Joints 04371-10011 oem
3B BJ70
delevery valve gasket : 22149-76010
rad cap : 16401-54750
water pump : 16100-59105
PS pump belt : 99343-11510
WP belt : 99343-01195
head gasket kit : 04112-58042
BJ74 13B-T Belts
Alternator: 22474 (NAPA)
Power Steering: 22607 (NAPA)
A/C: 17405 (Goodyear)
3B/13BT waterpump interchangability:
16100-95105
84/11-88/08 3B/13BT
88/08-90/01 13BT
hth's
gb
Air Filter cross over numbers for 2H, 12HT, 3B, 13BT and more...
TRD Oiled Air filter part number is: COTRA-17801-06
K&N oiled Air filter E2440
Toyota paper is 17801-68020 and 60040
Fram air filter CA376
Wix air filter 42159
Napa air filter 2159
Motorcraft air filter FA584R
3B/13 BT Solid clutch fan kit.
16365-18010 Spacer
16365-18010-FA Adapter plate
GB
I found a fuel filter for the 2H, 12HT, 3B, 13BT at Fleetguard the other day
Fleetguard FF5114 (use in place of Toyota 23303-56031)
Fleetguard filter numbers
Oil Filter 3B/13BT LF3313 for the basic and LF3487 for the upgraded filter.
Oil Filter 12HT LF3399
Fuel Filter 13BT/2H/12HT LF5138
Fuel Filter 3B LF5114 (daryl, the 13BT/2H/12HT is a slightly longer filter, but the 3B will work).
Andre...no need to have as a sticky. It can be accessed from the FAQ thread which is the main sticky.
hth's
gb
3B 12V voltage regulator - w/ inc regulator:
OEM : 27700-57060 : ±290$
OEM remanufactured for Toyota by Denso 27700-5760-84 : ±80$
Transpo : IN218 - ±30$ (http://195.125.241.148/cgi-win/product.exe?IN218)
Starter contacts for 3B found at Lordco. Part number from the Lordco invoice as follows:
Starter contacts: Wilson 45-29-6522 less than $10
Plunger: Wilson 45-29-6452 $12
Internal IC Regulator: Wilson 62-29-16029 looks the same but not yet tested (it's my spare) about $70
Primer can be replaced with a Bosch 2 447 010 038 'cause I just did that on my BJ60. This one doesn't require you to loosen it to pump.
[size=+1]H,2H AND 12H-T ENGINES[/SIZE]
2H/12HT filter numbers
Napa Gold Air Filter 2159 (see air filter post below)
Napa Gold Fuel Filter 3393 (Good for 13BT too)
Napa Gold Oil Filter 1627 - Cross from LF3399 and Toyota 15601-68010
gb
Beck/Arnley Air Filter 042-1456
Beck/Arnley Oil Filter 041-8193
gb
In my 2H I use the E2443 model ..
Someo of my part numebrs...
ARB Air Locker Long cross shaft for semi-floaters 060205
ARB Air Locker Pinion Thrust Washer 151102
(You don't want to know why I have those numbers!)
-Pinion Large Bearing Koyo ST4090-N need 1 30308 92KA1
30306 92KA1 small bearing
-Inner Axle Koyo 17887(bearing), 17831 (race)
-input Bearing Koyo 6207T6 need two
-Front output Bearing Koyo TR070902
-Rear Output Bearing koyo 30307T2 race 30307J
-Rear Semi floater Axle Bearing Koyo RNU0727. Not available through bearing suppliers, but a Koyo bearing shows up in a Federal Mogul box when purchased through the aftermarket suppliers. Koyo can't even order that bearing!
Timkin front axle bearing numbers
lm104948 bearing
lm104910 race
lm102949 bearing
lm102910 race
-K&N Air Filter #E2440
-Front Output Seal Toyota 90311-48002
-Rear Output Seal Toyota 90311-48003
-Tcase to tranny Seal 90311-78007
- Idler Pulley bearing for York Compressor NSK 6203
fuel filters
Fram P3627
Purolator F54469
Oil Filter -
Purolator L30001
for 2H engine
Kralinator L6
Glow Plugs 6V for 12V Superglow
Toyota 19850-68051
ND 067100-1680 6V
Glow Plugs 14V for 24V Superglow
Toyota 19850-68060
ND 067100-1460 14V
HJ61 12H-T
Master Cylinder:
No Toyota # yet...
Raybestos Lordco #MC39996
NAPA #P9885
Oil filter
Fuel Filter
Brake master cyl for HJ61 1989 ARL
47201 60380 Toyota AUST
Bull said:
Oil Filter Warning
for 2H engines oil filter #PH8A aka "8A" as listed above is not reccomended for 2H engines.
Why do I know this? I just popped 2 off my 2H, I called a oil filter tech hotline and they confirmed that the 2H diesel oil pressure exceeds the max oil pressure allowed by the 8A. I put a napa filter part #1627 and it works without issue and is probably twice the size of the 8A
12HT clutch part #s
Courtesy of gb:
Clutch PP: 31210-60100. This will be a North American number and can be had a Toyota. PP crosses with a slew of applications, including 13BT and 1HZ, even though EPC does not say so.
Clutch Disc: 31250-60170. This will be a North American number, and can be had at Toyota. 275mm disc that crosses with the FJ62.
Courtesy of my own research:
Pilot Bearing - 90363-15004 (Koyo 62022)
Release Bearing - 90363-45013 (Koyo RCT52S) (same as the FJ60s)
The Pilot bearing was available at BC bearing but the release bearing was a bit harder to get. It showed as a good number in their system but they said they didn’t know if or when they could get it and how much.
While you are doing the clutch, you might want to check out the rear main seal:
Rear Main - 90311-95002
Rear Main Gasket - 11383-68020
hth's
gb
water pump for 2h
Fenco P1329, (it will come up with a old or deleted number get the parts place to check with fenco direct. they do still supply them under land cruisers, or heavy duty/toyota forklifts)
Full Float axle seal:
CR 13911
Alternator Belt:
Toyota 99343-11095 ($27 CAD)
Power Steering Belt:
Toyota 90916-02153 ($17 CAD)
A/C Belt:
Toyota 99332-01395 ($21 CAD)
HJ45 "H" Diesel
Air Filter: Carquest 87093
Fuel Filter: Napa Gold 3166
[size=+1]1HZ ENGINES[/SIZE]
1HZ / 1HDT
Oil filter 90915-30002/90915-03006 or 15600-41010
Fuel filter (primary) 23303-64010
Dave
STP SA376, also fits 1HD-T, US$12 at Autozone in Maine
Pulled from a Jimmy B post.....................
Stock 1HZ Toyota fuel filter prt #23303-64010
For aftermarket the following part numbers
Donaldson P550385
Baldwin BF7535
Luberfiner G2920
Wix 33138
For 1HZ engine oil filter- toyota prt #90915-30002
Donaldson P550597
Baldwin BD7029
Luberfiner LFP5971
Check with the local toyota dealer on the oil filter,locally it was the cheapest over the counter price about $26.00
James...
[size=+1]1HD-T ENGINES[/SIZE]
04May2005 (UTC -8)
Dave, would you believe that my 1995 FZJ-80 (Arab-spec) had a 1HD-T engine oil filter on it when I purchased it? I couldn't believe it when I saw it, but it seemed to have no problems --no oil leaks, no loss in oil pressure, no problem.
I checked the o-ring on both the 2UZ-FE/1FZ-FE oil filter and the metal part where it seals the 1FZ-FE engine, and it's identical in size and thread to the 1HD-T oil filter.
Changed it to the smaller 2UZ-FE/1FZ-FE oil filter of course, but I do wonder what would have been the benefits/issues/troubles if I kept that 1HD-T engine oil filter in there?
No idea, but the 15600-41010 is visibly larger than the other. Maybe it is meant for different markets with different driving conditions? That is good info, Drexx, now we know the 1HZ/1HDT filter fits the 1FZFE and the 2UZFE!
Dave
Tried the 15600-41010 on my 1HD-T, no fit, left me in a right pickle. Gonna order the 30002 from Toyota tomorrow.
Gasket part numbers for the CT-26 turbo (on a 1HD-T) :
70sguy said:
Gasket, Turbo oil inlet 15471-58010
Gasket, water bypass 16347-42020
Gasket, turbo to ex manifold 17278-88380
Gasket, turbine outlet elbow 17279-17020
The second two are steel and probably fine just fine to reuse.
The first two may come with your RB turbo but if you want a set to be sure. The first 3 are good North American Toyota numbers.
[size=+1]2L, 2L-T, 2LTE and LATER VERSIONS OF LIGHT DIESEL[/size]
2L-T parts number:
Air Filter: 17801-54080
Diesel-Filter: 23303-64010
Oil Filter: 15600-41010 (MANN FILTER: W940/81)
Timing Belt (TDLER): 13505-54010
Timing Belt (belt): 13568-59027
Cylinder KIT (clutch): 04313-12030
Red Herring said:
HJ61 12H-T
Master Cylinder:
No Toyota # yet...
Oil filter
Toyota #15600 41010
I thought the E2443 fits in a 3F engine .. in the K&N web site I found the cross reference to my 2H why I don't know .. but the E2440 appears for 2F engine and not fit in my 2H .. not sure anycase.
Belts HJ61 12HT Jap spec. 1989 model
These FIT, but are not necessarily spec sizes. Spec sizes seem to be different and may not fit. Best option is to replace all your belts with the new ones BEFORE your big adventure, and keep the old ones as spares, rather than buy new to keep as spares. This way you get practised at changing the belts, and you know the ones you buy will fit BEFORE you go.
Alternator belt
Bosch (Australia) 15A 1080
Mitsubishi REMF 8420
Power Steering
Bosch (Australia) 15A 0890
Mitsubishi REMF 8340
Air conditioner
Bosch (Australia) 13A 1410
Mitsubishi MPMF 6540
Charge lamp relay : 27790-13010
Standard motor product : RY-379
also fit on :
4RUNNER & PICK UP 87-84
LAND CRUISER 90-80
STARLET 84-81
TERCEL 84-82
COROLLA 87-84
CAMRY 85-84
3B clutch fan (not fan clutch) is the same as a 94-97 Tacoma, at least that's what the one on my '82 BJ60 is marked as being for.
BJ74 MONROE SHOCKS ABSORBERS
FR Gas Magnum #34959
RE Sensa-Trac #58497 rear for towing and hauling
GB
Glow Plug Numbers
Manual 12V
10.5V for a 12V Cruiser
1980/10 – 1981/10 Cdn Spec BJ60
Toyota=19850-68010 12V-10.5V
Nippon Denso=067100-1330
NGK 7493 (Y-147T old number)
Bosch 0250 202 058
8.5V plugs for a 12V Cruiser
Toyota 19850-68030 12V-8.5V
NGK Y-128T
ND 067100-1350
APS 5013
EIKO GT208
JKT PT104
MAY PT104
Manual 24V
1980/08 – 1981/10 BJ42
1978/03 – 1980/06 BJ40
Toyota=19850-68040 24V-20.3V
Nippon Denso=067100-1161
NGK 3030 (Y-178T old number)
Bosch ???
Superglow 12V
1981/10 – 1985/10 BJ60
1984/11 – 1986/08 BJ70
Toyota=19850-68050 (51) 12V-6V
Nippon Denso=067100-1680
NGK ???
Bosch GPT-214
HKT PT-146 QGS type
Champion CH-125
Superglow 24V
1986/08 --> BJ70
1985/10 --> HJ60
1981/10 – 1984/10 BJ42
Toyota=19850-68060 24V-14V
Nippon Denso=067100-1460
NGK 2188 (Y-197R old number)
Bosch 0250 202 076
12Ht oil filters:
TOYOTA 15601-68010
No info
Donaldson P550707
OD: 4.27”
Height: 5.63”
Thread: M30 X 1.5
Gasket OD: 3.3”
Relief Setting: 18-21 PSI
Anti-drain valve: Yes
Micron rating:
Fleetguard LF 3399
OD: 4.239”
Height: 5.715”
Thread: M30 X 1.5-6H INT
BPV Setting: 32.49 PSI
Micron rating:
Luberfiner LFP923
OD: 4.28”
Height: 5.69”
Thread: M30 x 1.5
Micron rating:
NAPA Gold 1627
OD: 4.252”
Height: 5.571”
Thread: 30 x 1.50mm
Gasket ID: 3”
Gasket OD: 3.4”
Gasket Thickness: 0.31”
Micron rating:
WIX 51627
OD: 4.252”
Height: 5.571”
Thread: 30 x 1.50mm
Gasket ID: 3”
Gasket OD: 3.4”
By-Pass Valve Setting: 10 PSI
Micron rating:
Fram PH4704
No web info
Baldwin BT 221
O.D. : 4 1/4"
Height : 5 5/8"
Thread : M30 x 1.5
By-pass valve : 32 PSI
NC momentary switch, for glow screen over-ride.
Cole Hersee CO. MFG Part # 9087
Oil filters 30002-8T vs 30002
Got a new Toyota oil filter for a 1HD-FTE engine. The number is 90915-30002-8T, by Denso.
I also have a filter without the 8T at the end. Anybody knows the difference?
The 90915-30002s I got have a different Denso number, 115410-0161. Are you sure about your number?
The old 90915-30002 I've got has the same Denso number you have on your's.
The new 90915-30002-8T is Denso # BT115410-0840, made in Thailand.
Haven't figured out the difference yet.
2H exhaust manifold gaskets (6):
Single piece manifold: 17173-68010
Two piece manifold: 17173-76012-71 (please verify)
3B 13B-T engine belts
WP Fan & Alt
99343-01195 (Toyota)
(Metric Part Nos.)
PS pump
99343-11510 (Toyota)
15A1510
to
15A1595
AC compressor
99343- 01045 (Toyota)
13A0915
to
13A1045
NOTE that "to" indicates a range of sizes.
The metric size number is the belt width in millimeters and the belt length in millimeters.
thus 15A1195 to 15A1205 indicates a belt length between 1.195 meters and 1.205 meters, or ~47 inches to ~47.5 inches
note that the correct Toyota part numbers are also indicating the length in millimeters.
3B injector pump diaphragm
From lowenbrau: the Nippondenso part number for the 3B injector pump diaphragm is 090580-0041
Same part for the 2H with manual transmission
No rotary pumps use the diaphagm, I don't think. Neither do the inline pump on the 13BT or 12HT, or 2H with auto trans.
3B Donaldson filter numbers
Fuel P550057
Oil P550008
2H Radiator Hoses:
Lower Hose
OEM - 1657268020
Mackay Rubber - CH1343
Upper Hose
OEM - 1657168020
Mackay Rubber - CH1342
Bypass Hose
Gates - 02-0114
I have only found these from Roodogs in Australia so far (http://www.roodogs4wd.com.au). Great prices and fast shipping.
