Nope not for now, I wanted to do a little project of designing my own turbo to see how little boost I could use to get 200hp with no cooler. Only showed 195hp on this run but it makes 200. They guys doing the dyno didn't realise my turbo setup was designed to make peak power at max RPM and they kept stopping the run just after 3000 like they normally do with normal setups (I don't like normal haha), each run they did I could see the Nm/hp drop slightly each time as the sealed dyno booth was becoming a sauna@KiwiDingo
Are you still running the eclipse turbo ?
For comparison to the Eclipse I was running previously, according to the dyno which is a different dyno, I've lost a bit early on and peak power is at different rpm which I purposely designed that way. I'm a big believer in using the full engine RPM and having a turbo designed to still allow me to have a rising power curve at max RPM is key to this, otherwise you keep needing to change gears early to continue accelerating. Plus making 200hp at 4000 is a lot safer on the engine in terms of peak cylinder pressures than making it at 3000.
Eclipse turbo - 150kw-200hp/555Nm @24psi, PDI front mount cooler, 4.1 ratio diffs, max EGT on test hill 750 degrees C
- EMP during spool and at peak boost 1.3:1, at max RPM 1.6:1
Custom CT26 - 145kw-195hp/480Nm @13psi, No cooler, 3.7 ratio diffs, max EGT on test hill 600 degrees C
- EMP during spool and at peak boost 0.7:1, at max RPM 0.9:1
Also don't let this low boost really tame 200hp tune fool you, this turbo can easily hit 22psi before 2000RPM! This was just purely a project of mine and a bit of a competition I had with mates about who can make 200hp with the lowest boost. So much for 9 blade turbines being only good for ricers
Once again it seem like the usual case of death by fire squad around here from the usual suspects for anyone sharing thoughts or opinions of their own setups or ways of doing things that differ from the square box they live in.
