Just did waiting for him to replyCall this guy while you're at it:
http://www.nc4x4.com/forum/index.php?threads/parting-out-a-91-fj80.156964/
Ok, I lied about the piehole being shut. If your are basing the above on my post, I did not say the bearings are bad. I did say that they are likely getting damaged (lead often comes from the bearings). The ONLY way to check the bearings is to perform a tear down and lay eyes on them ....
Can you help me do that?....To add to that, the accelerated wear is probably due to the small amount water in the oil. I bet it'd go back down after the now confirmed oil-coolant mix problem is fixed.
Maybe we should have trusted the dye in the first place?
Help you do what, call Terry? Talk to him, go over your symptoms and see if they line up with what he experienced before having his head welded.
No he's at work and bypassing the oil cooler
Aloha, all! John, I'm sorry to hear that you're having all of these issues, especially after having your head work done at a dealership. I read through all of this and some of it is confusing, so I'll just ask some questions and make some comments. I'm no mechanic, but unfortunately, I've had to deal with this twice, so I'll be glad to kick in my limited knowledge.
1. The compression test shows 175psi on all cylinders? That's about 26 psi higher than the FSM calls for. I have no idea if that is an issue, but it's something that I noticed.
2. A coolant pressure test has been done with no loss of pressure? Hot and cold?
3. The recent pics from Johnny's shows some pretty good gunk in the valve cover. Is this not the dreaded "milkshake" that's indicative of a head gasket issue? Mine looked like that the second time.
4. For the record, the first time mine blew, it was a catastrophic failure. The radiator blew a fist sized hole and before I realized it, the truck had overheated and blew the gasket, so I didn't have the chance to notice symptoms. The second time, there was a crack at one of the valve seats and I had it welded by a company in Goldsboro. https://plus.google.com/109644501657640893273/about?hl=en This guy apparently welds a ton of heads for backhoes, forklifts, etc. If you need this service done, make sure you get him to tap the oil freeze plug. I forgot and it bothers me.
5. It sounds like you're losing a ton of coolant, obviously it has to be going somewhere. I know it's cold there, now, but could the heater core be bypassed to see if it is the culprit?
6. When I was having my second issue, I used the FSM and went through step by step by step that it outlines. If you don't have one, you owe it to yourself to get one. There are no shortcuts and it's the most concise and precise way to troubleshoot.
7. I was having a ton of white smoke on start up and until it got to operating temperature. It was a lot more noticeable than what you seem to have going on.
Okay. Well done it multiple times never shown any yellows not like I need some blue Kool-Aid in there. Last time I blew my head gasket white smoke came out it was running like s*** vibrating real bad but now I have none of that it's just a little bit of white smoke when you started up in the morningand I checked with the warranty department I'm out of warranty by five months is a one-year warrantyNo offense but that head gasket test result is a little suspect in my opinion. You have white smoke on start up and a lot according to you. Blackstone confirms antifreeze is in the oil. If that does not scream head gasket I don't know what does. Didn't you have the head gasket test done at the dealership? The same dealership that did the original work? If that's the case they are ****ing with you and just hope you go away.
