This will only work on the older pulleys with a replaceable bearing (see next post). The early idler pulleys had a replaceable bearing, part number 6204 with double seals. This includes KOYO 6204-2RS, NSK 6204VV,and NTN (Natchi) 6204-LLU. The NTN is the bearing you will probably find when you remove the bearing. Just about any 6204 with double seals will work, as long as the center is 20mm. I've seen a bearing out of China that was smaller and didn't work.
OK, what needs to happen. This is extremely easy boys.
First remove the pulley from the engine. Note the bits and what order they come off and in what direction. The pulley should look like this when you have it on the bench:
Next remove the spring clip. BE CAREFUL. It will launch across the garage and you will never find it. This spring is NOT available from Toyota as a separate item.
Now, time to press out the bearing. You have several choices here. It can be pounded out with a socket and BFH:
Or, it can be pressed out using what ever method you wish. Here I'm using a socket to push the bearing out, and backing the bearing up in the vice with a large pitman arm puller.
Use what ever method you wish.
Time to reinstall the new bearing. I use a seal driver and a vice to press the bearing in. I coat the inside of the pulley with a light coat of grease to help the bearing slip in smooth.
Install the clip and you are finished.
