Just recently installed a Ironman front bumper with a Bandland APEX 12K winch, and then finishing up the refreshment of the front suspension, including new UCA, new bushing for LCA/AHC shock and so on. Having gone through some of those existing AHC/TB posts, I realize I may have to deal with the TB for the added weight, before bolting the TB back. However, don't have much experience on this topic, so asking for the community's expertise.
Before the added weight, the TB adjustment bolt has gone through about 2/3 threads, as shown in the picture below. Do you think it has enough thread to adjust for the added weight without re-indexing?
forum.ih8mud.com
Any help is appreciated.
Basic info:
- 2004 LX470 with working AHC with all 4 globes replaced 2 years ago.
- Added ~280 lbin the front:
- Added 82 lb: Badland APEX 12K winch
- Added 108 lb: Ironman Front Bumpter
- Shared 60 lb: of 180 lb Tuff Stuff Alpha RTT
- Misc 30 lb
Q1: Could the OE TB be enough for the added weight?
This is actually 2 questions here:- Can I keep the OE TB?
- If having to, what TB should go to? LC100? LC80? or aftermarket?
- Do I have to re-index?
Q2: How to enable the OE TB for re-indexing?
I searched the forum but couldn't find similar situation. So don't know if it's just mine. However, it looks like the OE TB is not re-index-able, as there is only 1 position for the TB to fit into the sleeve, as in the pictures. One slot on the TB spine was filled. Therefore, that filled slot has to be bit into the widen slot on the sleeve. To be able to re-index, the filled material has to be removed. How could it be removed?Q3: How many degrees (teeth) to turn for re-index?
The following post has detail instructions on re-indexing with nice pictures. However, it's for non-AHC and didn't specify how many teeth to turn when re-indexing at step 6.For those with torsion bar questions
Torsion bars 101 FOR NON AHC VEHICLES First some terms so the search function picks this up: - help with torsion bars - how to adjust torsion bars - reindex torsion bars This all went in Amy's thread but I thought those who weren't subscribes may like to see it. Ok lets try get to the...
