ARCHIVE Tandem Off-road 2G Sequoia Rear Bumper Install Instructions (2 Viewers)
Installation Instructions
mexellent
1699192075056-png.3473510
This thread is to outline the installation of the Tandem Off-road rear bumper.
The Sequoia has an integrated hitch into frame which makes it difficult to mount a rear bumper to the truck. There are two factory point on the frame with two bolt holes each that are used to mount the bumper. There are two systems of "clamps", one located at the front of the bumper (forward clamp) and one on the rear of the frame on the member where the hitch is welded to (rear clamp).
Installation Time: 15-20hrs
ItemDescriptionLocationQuantity
1BumperOn the back of the truck lol1
2Left Swing OutLeft side of bumper1
3Right Swing OutRight Side of bumper1
4Tire CarrierLeft or Right side of bumper2
5LatchSwingout2
6Latch HandleLatch2
7Swingout PinSwingout2
8Left HingeSwingout Storage Door2
9Right HingeSwingout Storage Door2
10Little LatchSwingout Storage Door2
11Rubber Grommets3 per Swingouts6
12Flat Head M8 x1.25 x 16mmHold down the pin plate8
136-32 x 0.4375" SS Socket HeadSwingout Storage Door16
14SS Washer #6Swingout Storage Door16
15M6 x 1 x 30mm SS Flat HeadHolds Latch handle onto Latch4
16M6 x 1 Nylock NutHolds Latch handle onto Latch4
17M6 x 1 x 16mm Socket Head ZincSwing Arm Strike Pads8
18Strike PadsBumper between swingouts4
19M8 x 1.25 x 30mm Zinc Flange HexForward Frame Clamps to frame and bumper16
20M8 x 1.25 NYLOCK Zinc NutForward Frame Clamps to frame and bumper16
21Zinc Washers for 8mmForward Frame Clamps to frame and bumper16
22M6 x 1 x 14mm Flat Head Socket ZincSwingout Locking Pin to Swing Out4
23M6 x 1 NylockSwingout Locking Pin To Swing Out4
24M4 x 0.7 Stainless Steel Button Head ScrewSensor Mount to Bumper8
25M4 x 0.7 NylockSensor Mount to Bumper8
26M4 WasherSensor Mount to Bumper16
27M12 x 1.25 x 40mm zinc boltBumper to bottom of Frame Bolt Holes4
28M12 x 1.75 Nylock Yellow ZincBumper to Frame Clamp8
29M12 x 1.75 x 40mm Flanged Yellow ZincBumper to Frame Clamp8
30M12 WashersBumper to Frame Clamp16
3110mm x 16mm Shoulder boltFrame Clamp Pin4
32Left SS Pin PlateBottom of Left Swing Out Spindle1
33Right SS Pin PlateBottom of Right Swing Out Spindle1
34M8 x 1.25 x 16mm button head cap screwLatch to swing arm and Latch Catch to bumper8
35BearingsSwingout (2 per swing out)4
36SealSwingout Spindle (1 per swing out)2
37Spindle CapSwingout Spindle (1 per swing out)2
38Extended Length Drill Bit 25/64" dia. 7" lengthUsed to drill hole to pin clamps in place1
39Lower Clamp Shim (thick)Used between the frame and the bumper clamp2
40Lower Clamp Shim (medium)Used between the frame and the bumper clamp2
41Lower Clamp Shim (thin)Used between the frame and the bumper clamp2
42Upper Clamp Shim (thick)Used between the frame and the bumper clamp2
43Upper Clamp Shim (medium)Used between the frame and the bumper clamp2
44Upper Clamp Shim (thin)Used between the frame and the bumper clamp2
45Bumper to Frame shimsUsed between the frame factory bolt holes and the bumper4
46Bumper Bolt Load DistributorsUsed as a big washer for the bolts that go into the frame2
47Sensor MountsUsed to mount the parking sensors to the bumper4
48Storage DoorSwingout2
49Forward Frame ClampsFrame4
50Forward Frame Clamp ArmForward Frame Clamps2
51Left Rear Frame Clamp SpacerLeft Rear Bumper Frame Clamp1
52Right Rear Frame Clamp SpacerRight Rear Bumper Frame Clamp1
53Air Suspension Pump SkidBumper - Driver Side1
54
Step 1: Assemble the Bumper
  • Mount the Left and right Pin Plates to the bumper
  • Mount the Swing Arm Strike Pads to the bumper
  • Mount the Lightforce Rok40 flush mount lights to the bumper (optional)
Step 2: Assemble the Swing Outs
  • Install the Storage Doors
    • The hinges are side specific and must be mounted a specific way. (see picture below)
    • The Storage Door Latches will need a little bit of fiddling to get right.
  • Install the rubber grommets in the doors so you can run cables through them without worrying about chafing.
  • Install the Latches on to the Swing Outs. Be careful when you screw on the bottom bolt as it is shallow and it may strike the metal behind it.
  • Wait to install the Tire Carrier once the Swing Outs are mounted to the bumper (optional but it will make your life easier)
Step 3: Remove the factory Rear Bumper
  • Remove the factory mud flaps
  • Disconnect the backup sensor harness from the vehicle
  • Remove the factory rear bumper (save this for later)
  • Remove the factory bumper support brackets located at the back of the vehicle
  • Remove the bumper/mudflap supports located behind the rear tire
  • Remove top bumper supports
Step 4: Prepare for test fit
  • Remove the Trailer Plugs bolted to the frame and set these aside
  • Make Clearance to slip the bumper on by trimming and folding in some tabs
  • Hammer the trailer plug tab against the frame
  • Cut the "skirts" hanging off the body on the left and right side of the vehicle
  • Grind off big welds on the frame as necessary. There may be some welds on the bottom of the frame that need to be ground off for the bumper to sit flush on to the frame.
Step 5: Test Fit the bumper
  • With the help of a friend, pick up the bumper and place it on the truck. Careful not to scratch the paint.
    • PRO TIP: We like to use height adjustable tables. Super handy for putting bumpers on and when youre not using them to put on bumpers you can use them as tables.
  • Line up the two holes on the bottom of the bumper with the holes in the bottom of the frame. Use the provided bolts and Bumper Bolt Load Distributor to check initial fit. Load distributor goes between the bumper and the bolts. In the picture below, there are no load distributors but you should use them because the holes are oversized to allow for adjustment. Put the bolts in by hand. Do not impact them. You may need to run a tap through them because of rust or paint.
    • Check the fit on the left side of the body
    • Check the fit on the right side of the body
    • There is a gap designed between the bumper and the body to allow the body to move separately from the body and thus prevent damage to the body during flex or bumps.
  • Recommended fit should look something like this:
    • Add shims between the bottom of the frame and the bumper to bring the bumper down
  • Test fit will look like this:
Step 6: Prepare to trim factory bumper
  • Remove parking sensors and sensor harness
  • Start to trim factory bumper. The first trim is the "Rough trim"
    • Here is a template we are working on.
    • Template explained
    • The white line on the bumper is approximately where your first trim will be
    • This is what the bumper will look like after the first trim
    • Remove the rear bumper from the truck and put the trimmed piece back on the truck
    • Now try to put the bumper back on the truck. It will probably not go on because there will need to be more trimming on the factory bumper. You are putting the bumper on to see where you need to do additional trimming.
      • On the sides we trimmed the vertical parts so that they are flush with the Tandem Bumper. There is a gap here because the bumper is not bolted on:
      • Gap goes away when bumper is bolted on. Apply weather stripping to clean up the aesthetics later on.
Reserved
Reserved
Reserved
It's a living document with instructions for installation of the bumper. I'll write the instructions here and if people run into problems then we can address them here once and other people can see how to resolve the problems as well.
