I've got an older Delta contractor's saw. I've been making some picture frames and other smaller projects with it. Good old saw, but I've often wished for more capability.
I've got the basic incra miter guide and it has the factory fence. I've also added a tenoning jig.
Next tool is a sled. I built a good base for one yesterday. Just a flat piece of 1/2" plywood and I cut two strips of solid cherry for the slots - I figured a hardwood would last longer and I had some 13/16" leftover that was easy to mill down to fit tightly.
Now that I've got a base - what do you like or dislike about your setup and how would you build again if you were starting over? I'm mostly curious about what you've done for adjustable fences and mitering? I saw one sled idea online with a more or less fixed set of 45* guides for making quick accurate mitered joints. I'm thinking that may be a good way to go.
Second, what are your thoughts on adding a router base to the table saw? I've got a cheap $50 router table that sucks. I'd very much like to use the table saw for this, but I'm not sure whether I should try to modify one of the wing areas to fit the table from the current router table - basically I'd cut it apart, weld in new flanges and bolt in the table top part from my cheap router table, or would I be better off just to start from scratch? It would be awesome to be able to mount the router approximately inline with the blade so I could use all the regular table saw jigs, but I don't see how that would be possible. I think cutting into the cast iron top would be hard to do. -what have you found works best? What would you do again?
(Unfortunately I really don't have room for another full size table for the router. If I did I'd find a table from the same type of saw and mount the router in the carriage from the saw, then all the jigs would cross over and I could adjust height etc from outside the cabinet, but I just don't have the room)
Thanks,
Thanks,
