lckarl
- Thread starter
- #41
Yes that is a TD04L turbine, its the middle size turbine wheel. The 19T looking at the maps should preform very well all over the 4BD RPM range. I plan to run mine in the 20-25psi range. The TD04HL i have is almost the same size turbine as a the small TD05 so should work will with the 6cm turbine housing. The turbo you have will work well for a lower boost I have a feeling it will run out of breath though. The great thing with these turbos is they are cheap and there is lots of upgrades that can be done. All sorts of different size wheels and covers. I have only seen one 4BD1T with compounds and it was running a big plunger pump and other mods. If you are keeping the stock pump i would not worry about it. Just try what you have if it runs out of steam get a 19T upgrade kit and rebuild the turbo with that.
I do have a thread on here in the diesel section: https://forum.ih8mud.com/diesel-tec...uzu-4bd1t-lexus-lx450-land-cruiser-build.html
Cheers
I'll check out the build thread.
I wasn't sure if the "L" denoted a certain size, model, etc. You see them also with an "H", but you also see them with actual numbers denoting specifics, 13g, 15g, 19t. Then you have 04,05,06. I haven't seen anything above an 06, but as you mentioned the great thing about the 04's is they are cheap as turbo's go (I got mine for $125.00 on Craigslist), since everyone seems to want to take them off their cars and put 05's on in there place. The internals that you bought on ebay, how did you determine their quality, when I look at some of that stuff I start to get worried that I am about to buy some junk?
In the pics below the engine is going in and getting bolted up, except for the front engine mounts which weren't made yet.
