I am about to install my 8274 winch on my 80. I dislike having power to the winch at all times, so I would like to be able to disconnect the power from the winch unless I am in a situation where I need it. On my 55, I just used separate terminal connectors to the battery and left the positive cable to the winch disconnected from the battery unless I was going to use it.
For my 80 I would like something a little more elegant. In searching the various threads it seems like people are using a variety of different types of marine battery switches. My concern is with the rating. My understanding (from Warn's website) is that the 8274 will pull 450 Amps at full load. Most the marine battery switches I have seen are only rated to 350 continuous. Do I need to go higher than that?
I did find one higher rated switch, but it is pretty expensive.
Here is an example of a 350 amp rated switch:
http://shop.torresen.com/ships_stor...rod_name=Switch+Battery+On/Off§ionid=2986
Here is one rated for 600 Amps continuous, but it is much more expensive.
http://shop.torresen.com/ships_store/index.php?p=details&mfc=BLUE SEA&sku=3000&frm=g
Do I need the higher rating, or is the 350 Amp sufficient?
Jared
Jared
