semlin
curmudgeon
has anyone swapped a 93-94 1fzfe into a 95-97 truck or vice versa? I am trying to figure out how much of the harness/sensors are plug and play.
Why would you want to put a 1fzfe in an FZJ?
Cuz that is what is in there! Not that Semlin is doing an engine swap.
(Sorry, couldn't resist to post since you are off my name by a "-"....)
93/94 into 95 and later you have to swap the pans and also the ring on the crank that is the crank position sensor triggers from. Probably the biggest part of the job.
95 or later into earlier, easier since you can just ignore the crank sensor.
I thought the early 80's were FJ80's and the last of the 80's were FZJ80's.
with any luck you'll already have a leaking rear arch seal and a fractured chain slipper and that will take some of the sting out of the job.
