I can't really tell what's been done to it, but I expect just fixing the sunroof would be less work than stripping it all out, welding it, doing body work, prime, paint, etc...
Not to mention you're going to lose significant value selling it. The crowd of people that want to buy a welded shut sunroof on a 100 is a lot smaller than the overall 100 buying crowd, unless the truck is generally just trashed all over.
Doesn't work. I tried. Not for more than a few weeks, anyway. YMMV, but I'm going to have to clean it off and go a different route.Flex Seal?
Really?For what it's worth, I would see it as a plus if I were shopping for another 100 and the seller had removed everything and welded in metal. Even with the original interior. Just keep the slide closed.
I did this for years on my old LR Disco. Worked like a champ, it was just ghetto looking and the adhesive made a mess.Honestly guys, I have had gorilla brand black duct tape sealing my minorly leaky sunroof closed for close to 4 years now. I've replaced it once.
It was one of those temporary but now permanent fixes. It works fine even if it is a little ghetto.
I think you are overthinking it.
I'm also thinking of welding one of my 100s. I see it as a plus. Do you think it's a 10% de-value or maybe a higher percentage? So that would mean I'm "losing" upwards of several hundred dollars over my years of ownership? Plus the only thing that I get out of it is the truck that "I" want and getting to be the ONLY one on this site to do it (according to the moderator).I can't really tell what's been done to it, but I expect just fixing the sunroof would be less work than stripping it all out, welding it, doing body work, prime, paint, etc...
If the sunroof doesn’t work, isn’t the value lost already? Sure someone could pay to have it fixed but I doubt anyone ever would. If you market the vehicle to the right person during resale I think the buyer would understand it’s actually an upgrade especially if it doesn’t leak. Just my two cents.I'm also thinking of welding one of my 100s. I see it as a plus. Do you think it's a 10% de-value or maybe a higher percentage? So that would mean I'm "losing" upwards of several hundred dollars over my years of ownership? Plus the only thing that I get out of it is the truck that "I" want and getting to be the ONLY one on this site to do it (according to the moderator).
Walmart sells a rubber reconditioning spray for RVs. I tried to hit every rubber bushing along with the sunroof seal as a preventative measure.I'd be tempted to apply something you can remove easily, to try to seal it up.
At a guess, something like MOLYKOTE 55 O-Ring Grease or similar.
It is meant to slightly swell existing o-rings and other rubber seals.
It doesn't seem to really dry or set. So could be worth coating the existing rubbers, and if that fails, perhaps flooding, within reason, around the top of the sunroof, any entry point, and water shouldn't get in.
I've never used it for this application, so its worth doing some research first - .i.e check its safe for paint, etc, but it could be a good way of sealing up a leaking sunroof without making it irreversible.
I have a slight leak with my sunroof on my new 105.
The controls to open it or tilt it do absolutely nothing - not sure yet if its the fuse, the motor, or what.
Ideally I'd like to open it, clean the whole mechanism, clean the drain pipes, and lubricate all the rubbers, but finding the time isn't happening at the moment.
As its a tiny leak, I might try the Molykote path one day first.
